GetSubEntity32 方法 (ActiveX)
对于 64 位系统,以交互方式获取对象或子实体。(已过时) 支持的平台:仅限 Windows 签名VBA: object.GetSubEntity32 Object, PickedPoint, TransMatrix, ContextData [, Prompt] 返回值 (RetVal)无返回值。 言论此方法要求 AutoCAD 用户通过在图形屏幕上选取一个点来选择对象。如果选取了对象或子实体,则在第一个参数中返回该对象或子实体,第二个参数将包含 WCS 坐标中选取的点。如果拾取点不在对象上,则该方法将失败。 此方法可以检索对象,即使该对象在屏幕上不可见或位于冻结图层上。 例子VBA: Sub Example_GetSubEntity()
' This example prompts the user to select on object on the screen with a mouse click,
' and returns some information about the selected object.
Dim Object As Object
Dim PickedPoint As Variant, TransMatrix As Variant, ContextData As Variant
Dim HasContextData As String
On Error GoTo NOT_ENTITY
TRYAGAIN:
MsgBox "Use the mouse to click on an object in the current drawing after dismissing this dialog box."
' Get information about selected object
ThisDrawing.Utility.GetSubEntity Object, PickedPoint, TransMatrix, ContextData
' Process and display selected object properties
HasContextData = IIf(VarType(ContextData) = vbEmpty, " does not ", " does ")
MsgBox "The object you chose was an: " & TypeName(Object) & vbCrLf & _
"Your point of selection was: " & PickedPoint(0) & ", " & _
PickedPoint(1) & ", " & _
PickedPoint(2) & vbCrLf & _
"This object" & HasContextData & "have nested objects."
Exit Sub
NOT_ENTITY:
' If you click on empty space or do not select an entity,
' this error will be generated
If MsgBox("You have not selected an object. Click OK to try again.", _
vbOKCancel & vbInformation) = vbOK Then
Resume TRYAGAIN
End If
可视化 LISP: (vl-load-com)
(defun c:Example_GetSubEntity()
;; This example prompts the user to select on object on the screen with a mouse click,
;; and returns some information about the selected object.
;; Get information about selected object
(vla-GetSubEntity (vla-get-Utility doc) 'Object 'PickedPoint 'TransMatrix 'ContextData "Select a subentity: ")
;; Process and display selected object properties
(if (/= ContextData nil)
(setq HasContextData " does ")
(setq HasContextData " does not ")
(alert (strcat "The object you chose was an: " (vla-get-ObjectName Object)
"\nYour point of selection was: " (rtos (vlax-safearray-get-element PickedPoint 0) 2) ", "
(rtos (vlax-safearray-get-element PickedPoint 1) 2) ", "
(rtos (vlax-safearray-get-element PickedPoint 2) 2)
"\nThis object" HasContextData "have nested objects."))
GMT+8, 2026-11-15 13:37
