EndPlot 事件 (ActiveX)
2024-5-18 18:46| 发布者: admin| 查看: 689| 评论: 0|原作者: admin|来自: AutoCAD
在将文档发送到打印机后触发。
object.EndPlot(DrawingName)
类型:应用程序,文档
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是应用程序或文档。
绘图名称
类型:字符串;输入到处理程序
已打印的图形的名称。
显示模式对话框时不会触发任何事件。
Private Sub AcadDocument_EndPlot(ByVal DrawingName As String)
    ' This example intercepts a drawing EndPlot event.
    ' This event is triggered when a drawing finishes a plot request.
    ' To trigger this example event: Plot an open drawing and wait for the plot to finish
    ' Use the "DrawingName" variable to determine which drawing just finished plotting
    MsgBox "A drawing has just finished a plot request!"
Not available
GMT+8, 2026-11-15 12:22
