WorkspacePath 属性 (ActiveX)
2024-5-18 18:46| 发布者: admin| 查看: 944| 评论: 0|原作者: admin|来自: AutoCAD
指定数据库工作区文件的路径。
object.WorkspacePath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
数据库工作区文件的驱动器、路径和文件名。
Sub Example_WorkspacePath()
    ' This example reads and modifies the preference value that controls
    ' the path for the database workspace file.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesFiles
    ' Get the files preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Files
    originalValue = ACADPref.WorkspacePath
    MsgBox "The WorkspacePath preference is set to: " & originalValue
    ' Modify the WorkspacePath preference by changing the path to "C:\"
    ACADPref.WorkspacePath = "C:\"
    newValue = ACADPref.WorkspacePath
    MsgBox "The WorkspacePath preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.WorkspacePath = originalValue
    MsgBox "The WorkspacePath preference was reset back to: " & originalValue
(defun c:Example_WorkspacePath()
    ;; This example reads and modifies the preference value that controls
    ;; the path for the database workspace file.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the files preferences object
    (setq ACADPref (vla-get-Files (vla-get-Preferences acadObj)))
    (setq originalValue (vla-get-WorkspacePath ACADPref))
    (alert (strcat "The WorkspacePath preference is set to: " originalValue))
    ;; Modify the WorkspacePath preference by changing the path to "C:\\"
    (vla-put-WorkspacePath ACADPref "C:\\")
    (alert (strcat "The WorkspacePath preference has been set to: " (vla-get-WorkspacePath ACADPref)))
    ;;         this preference in effect
    (vla-put-WorkspacePath ACADPref originalValue)
    (alert (strcat "The WorkspacePath preference was reset back to: " (vla-get-WorkspacePath ACADPref)))
GMT+8, 2026-11-15 12:40
