Viewports 属性 (ActiveX)
2024-5-18 18:46| 发布者: admin| 查看: 729| 评论: 0|原作者: admin|来自: AutoCAD
获取文档的 Viewports 集合。
object.Viewports
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型:视口
文档的集合。Viewports
Sub Example_Viewports()
    ' This example finds the current Viewports collection and
    ' adds a new viewport to that collection.
    Dim viewportColl As AcadViewports
    Set viewportColl = ThisDrawing.Viewports
    ' Create a viewport named "TEST" in the current drawing
    Dim viewportObj As AcadViewport
    Set viewportObj = viewportColl.Add("TEST")
    MsgBox "A new viewport called " & viewportObj.name & " has been added to the Viewports collection.", vbInformation, "Viewports Example"
(defun c:Example_Viewports()
    ;; This example finds the current Viewports collection and
    ;; adds a new viewport to that collection.
    (setq viewportColl (vla-get-Viewports doc))
    ;; Create a viewport named "TEST" in the current drawing
    (setq viewportObj (vla-Add viewportColl "TEST"))
    (alert (strcat "A new viewport called " (vla-get-Name viewportObj) " has been added to the Viewports collection."))
GMT+8, 2026-11-16 12:13
