StyleSheet 属性 (ActiveX)
指定布局或打印配置的样式表。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 样式表的名称。 言论没有其他评论。 例子VBA: Sub Example_StyleSheet()
' This example finds the name of the style sheet for the active layout
Dim styleSheetName As String
styleSheetName = ThisDrawing.ActiveLayout.StyleSheet
If styleSheetName = "" Then
MsgBox "There is no style sheet set for the active layout."
Else
MsgBox "The style sheet for the active layout is: " & styleSheetName
End If
可视化 LISP: (vl-load-com)
(defun c:Example_StyleSheet()
;; This example finds the name of the plot style for the active layout
(setq styleSheetName (vla-get-StyleSheet (vla-get-ActiveLayout doc)))
(if (= styleSheetName "")
(alert "There is no style sheet set for the active layout.")
(alert (strcat "The style sheet for the active layout is: " styleSheetName))
GMT+8, 2026-11-15 12:06
