StyleName 属性 (ActiveX)
2024-5-18 18:46| 发布者: admin| 查看: 803| 评论: 0|原作者: admin|来自: AutoCAD
指定用于对象的样式的名称。
object.StyleName
类型:Attribute、AttributeReference、Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated、Leader、MLeader、MLine、MText、Table、Text、Tolerance
此属性应用于的对象。
只读:不;只读对象除外MLine
类型:字符串
默认值等于当前样式。
使用对象更改给定文本样式的属性。使用对象更改给定维度样式的属性。TextStyleDimStyle
给定的名称必须已在图形中定义。
注意:对于尺寸,此属性的值存储在 DIMSTYLE 系统变量中。
Sub Example_StyleName()
    ' This example creates an aligned dimension and then changes the
    ' StyleName property for that dimension.
    Dim dimObj As AcadDimAligned
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    Dim currStyleName As String
    ' Define the dimension
    point1(0) = 5#: point1(1) = 3#: point1(2) = 0#
    point2(0) = 10#: point2(1) = 3#: point2(2) = 0#
    location(0) = 7.5: location(1) = 5#: location(2) = 0#
    ZoomAll
    currStyleName = dimObj.styleName
    MsgBox "The initial StyleName for the dimension is " & dimObj.styleName, vbInformation, "TextString Example"
    ' Create a new dimension style
    ThisDrawing.DimStyles.Add ("NewDimensionStyle")
    ' Change the text string for the dimension
    dimObj.styleName = "NewDimensionStyle"
    dimObj.Update
    MsgBox "The new StyleName for the dimension is " & dimObj.styleName, vbInformation, "TextString Example"
    ' Reset the text string for the dimension
    dimObj.styleName = currStyleName
    dimObj.Update
    MsgBox "The StyleName for the dimension has been reset to " & dimObj.styleName, vbInformation, "TextString Example"
(defun c:Example_StyleName()
    ;; This example creates an aligned dimension and then changes the
    ;; StyleName property for that dimension.
    ;; Define the dimension
    (setq point1 (vlax-3d-point 5 3 0)
          point2 (vlax-3d-point 10 3 0)
          location (vlax-3d-point 7.5 5 0))
    (vla-ZoomAll acadObj)
    (setq currStyleName (vla-get-StyleName dimObj))
    (alert (strcat "The initial StyleName for the dimension is " currStyleName))
    ;; Create a new dimension style
    (vla-Add (vla-get-DimStyles doc) "NewDimensionStyle")
    ;; Change the text string for the dimension
    (vla-put-StyleName dimObj "NewDimensionStyle")
    (vla-Update dimObj)
    (alert (strcat "The new StyleName for the dimension is " (vla-get-StyleName dimObj)))
    ;; Reset the text string for the dimension
    (vla-put-StyleName dimObj currStyleName)
    (vla-Update dimObj)
    (alert (strcat "The StyleName for the dimension has been reset to " (vla-get-StyleName dimObj)))
GMT+8, 2026-11-15 11:39
