SnapRotationAngle 属性 (ActiveX)
2024-5-18 18:46| 发布者: admin| 查看: 853| 评论: 0|原作者: admin|来自: AutoCAD
指定视口相对于当前 UCS 的捕捉旋转角度。
object.SnapRotationAngle
类型:PViewport、视口
此属性应用于的对象。
只读:不
类型:双
以弧度为单位的角度。有效范围为 0 到 6.28。
不能更改活动图纸空间视口的对齐基点。
在执行对 or 方法的调用之前,对此属性的更改不会反映在图形中。UpdateRegen
注意:此属性的值存储在 SNAPANG 系统变量中。
Sub Example_SnapRotationAngle()
    ' This example changes the snap rotation angle for a
    ' model space and paper space viewport.
    ' Create a new model space viewport
    Dim viewportObj As AcadViewport
    Set viewportObj = ThisDrawing.Viewports.Add("NewViewport")
    ' Find the current snap rotation angle
    Dim currSnapAngle As Double
    currSnapAngle = viewportObj.SnapRotationAngle
    MsgBox "The current model space snap rotation angle is " & viewportObj.SnapRotationAngle, , "SnapRotationAngle Example"
    ' Change the snap rotation angle
    viewportObj.SnapRotationAngle = 1.5
    MsgBox "The new model space snap rotation angle is " & viewportObj.SnapRotationAngle, , "SnapRotationAngle Example"
    ' Create a new paper space viewport
    Dim pviewportObj As AcadPViewport
    Dim center(0 To 2) As Double
    Dim width As Double
    Dim height As Double
    center(0) = 3: center(1) = 3: center(2) = 0
    width = 40
    height = 40
    ThisDrawing.ActiveSpace = acPaperSpace
    Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
    currSnapAngle = pviewportObj.SnapRotationAngle
    MsgBox "The current paper space snap rotation angle is " & pviewportObj.SnapRotationAngle, , "SnapRotationAngle Example"
    pviewportObj.SnapRotationAngle = 1.5
    MsgBox "The new paper space snap base point is " & pviewportObj.SnapRotationAngle, , "SnapRotationAngle Example"
(defun c:Example_SnapRotationAngle()
    ;; This example changes the snap rotation angle for a
    ;; model space and paper space viewport.
    ;; Create a new model space viewport
    (setq viewportObj (vla-Add (vla-get-Viewports doc) "NewViewport"))
    ;; Find the current snap rotation angle
    (setq currSnapAngle (vla-get-SnapRotationAngle viewportObj))
    (alert (strcat "The current model space snap rotation angle is " (rtos currSnapAngle 2)))
    ;; Change the snap rotation angle
    (vla-put-SnapRotationAngle viewportObj 1.5)
    (alert (strcat "The new model space snap rotation angle is " (rtos (vla-get-SnapRotationAngle viewportObj) 2)))
    ;; Create a new paper space viewport
    (setq center (vlax-3d-point 3 3 0)
          width 40
	         height 40)
    (vla-put-ActiveSpace doc acPaperSpace)
    (setq paperSpace (vla-get-PaperSpace doc))
    (setq pviewportObj (vla-AddPViewport paperSpace center width height))
    (setq currSnapAngle (vla-get-SnapRotationAngle pviewportObj))
    (alert (strcat "The current paper space snap rotation angle is " (rtos currSnapAngle 2)))
    (vla-put-SnapRotationAngle pviewportObj 1.5)
    (alert (strcat "The new paper space snap base point is " (rtos (vla-get-SnapRotationAngle pviewportObj) 2)))
GMT+8, 2026-11-15 11:59
