ShowRasterImage 属性 (ActiveX)
2024-5-18 18:46| 发布者: admin| 查看: 974| 评论: 0|原作者: admin|来自: AutoCAD
控制实时平移和缩放期间光栅图像的显示。
object.ShowRasterImage
类型:首选项显示
此属性应用于的对象。
只读:不
类型:布尔
  • True:在平移和缩放期间显示光栅图像内容。
  • False:在平移和缩放期间显示光栅图像轮廓。
此属性的初始值为 。False
如果拖动显示处于打开状态,并且您启用了 ,则在重新定位原始图像时,图像的副本将随光标移动。ShowRasterImage
注意:此属性的此值存储在 RTDISPLAY 系统变量中。
Sub Example_ShowRasterImage()
    ' ShowRasterImage. It then changes the value, and finally
    Dim currShowRasterImage As Boolean
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current ShowRasterImage value
    currShowRasterImage = preferences.DISPLAY.ShowRasterImage
    MsgBox "The current value for ShowRasterImage is " & preferences.DISPLAY.ShowRasterImage, vbInformation, "ShowRasterImage Example"
    ' Change the value for ShowRasterImage
    preferences.DISPLAY.ShowRasterImage = Not (currShowRasterImage)
    MsgBox "The new value for ShowRasterImage is " & preferences.DISPLAY.ShowRasterImage, vbInformation, "ShowRasterImage Example"
    ' Reset ShowRasterImage to its original value
    preferences.DISPLAY.ShowRasterImage = currShowRasterImage
    MsgBox "The ShowRasterImage value is reset to " & preferences.DISPLAY.ShowRasterImage, vbInformation, "ShowRasterImage Example"
(defun c:Example_ShowRasterImage()
    ;; ShowRasterImage. It then changes the value, and finally
    ;; Retrieve the current ShowRasterImage value
    (setq currShowRasterImage (vla-get-ShowRasterImage (vla-get-Display preferences)))
    (alert (strcat "The current value for ShowRasterImage is " (if (= currShowRasterImage :vlax-true) "True" "False")))
    ;; Change the value for ShowRasterImage
    (vla-put-ShowRasterImage (vla-get-Display preferences) (if (= currShowRasterImage :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The new value for ShowRasterImage is " (if (= (vla-get-ShowRasterImage (vla-get-Display preferences)) :vlax-true) "True" "False")))
    ;; Reset ShowRasterImage to its original value
    (vla-put-ShowRasterImage (vla-get-Display preferences) currShowRasterImage)
    (alert (strcat "The ShowRasterImage value is reset to " (if (= (vla-get-ShowRasterImage (vla-get-Display preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-11-15 13:26
