PrinterStyleSheetPath 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 644| 评论: 0|原作者: admin|来自: AutoCAD
指定打印机样式表文件的位置。
object.PrinterStyleSheetPath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
打印机样式表文件的驱动器和路径。
使用分号 (;) 分隔多个目录;但是,不要以分号结束字符串。
Sub Example_PrinterStyleSheetPath()
    ' This example reads and modifies the preference value that controls
    ' the location for printer style sheet files.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesFiles
    ' Get the files preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Files
    originalValue = ACADPref.PrinterStyleSheetPath
    MsgBox "The PrinterStyleSheetPath preference is set to: " & originalValue
    ' Modify the PrinterStyleSheetPath preference by changing the path to "C:\"
    ACADPref.PrinterStyleSheetPath = "C:\"
    newValue = ACADPref.PrinterStyleSheetPath
    MsgBox "The PrinterStyleSheetPath preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.PrinterStyleSheetPath = originalValue
    MsgBox "The PrinterStyleSheetPath preference was reset back to: " & originalValue
(defun c:Example_PrinterStyleSheetPath()
    ;; This example reads and modifies the preference value that controls
    ;; the location for printer style sheet files.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-PrinterStyleSheetPath (vla-get-Files preferences)))
    (alert (strcat "The PrinterStyleSheetPath preference is set to: " originalValue))
    ;; Modify the PrinterStyleSheetPath preference by changing the path to "C:\\"
    (vla-put-PrinterStyleSheetPath (vla-get-Files preferences) "C:\\")
    (setq newValue (vla-get-PrinterStyleSheetPath (vla-get-Files preferences)))
    (alert (strcat "The PrinterStyleSheetPath preference has been set to: " newValue))
    ;;         this preference in effect
    (vla-put-PrinterStyleSheetPath (vla-get-Files preferences) originalValue)
    (alert (strcat "The PrinterStyleSheetPath preference was reset back to: " originalValue))
GMT+8, 2026-11-15 12:11
