PrimaryUnitsPrecision 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 838| 评论: 0|原作者: admin|来自: AutoCAD
指定为尺寸或公差的主要单位显示的小数位数。
object.PrimaryUnitsPrecision
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:枚举acDimPrecision
  • acDimPrecisionZero: 0.
  • acDimPrecisionOne: 0.0
  • acDimPrecisionTwo: 0.00
  • acDimPrecisionThree: 0.000
  • acDimPrecisionFour: 0.0000
  • acDimPrecisionFive: 0.00000
  • acDimPrecisionSix: 0.000000
  • acDimPrecisionSeven: 0.0000000
  • acDimPrecisionEight: 0.00000000
注意:此属性将覆盖给定维度的 DIMDEC 系统变量的值。
Sub Example_PrimaryUnitsPrecision()
    ' uses PrimaryUnitsPrecision to allow the user to change
    ' the number of decimal places displayed for the primary units and tolerance
    ' units of the dimension.
    Dim dimObj As AcadDimAligned
    Dim oldPrecision As String, newPrecision As String
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5.12345678: point2(1) = 5: point2(2) = 0
    ' Enable and setup tolerance display
    dimObj.ToleranceDisplay = acTolSymmetrical
    dimObj.ToleranceLowerLimit = -0.0001
    dimObj.ToleranceUpperLimit = 0.005
    ' Store old precision value as default for input box
    oldPrecision = dimObj.PrimaryUnitsPrecision
    ' Allow the user to change the precision for the dimension and dimension tolerance
    newPrecision = InputBox("Enter a new precision for the dimension and tolerances.  The value must range from 0 to 8.", "Change Precision", oldPrecision)
    Select Case newPrecision
        Case 0: newPrecision = acDimPrecisionZero
        Case 1: newPrecision = acDimPrecisionOne
        Case 2: newPrecision = acDimPrecisionTwo
        Case 3: newPrecision = acDimPrecisionThree
        Case 4: newPrecision = acDimPrecisionFour
        Case 5: newPrecision = acDimPrecisionFive
        Case 6: newPrecision = acDimPrecisionSix
        Case 7: newPrecision = acDimPrecisionSeven
        Case 8: newPrecision = acDimPrecisionEight
        Case Else
            MsgBox "The precision has not been changed."
            Exit Sub
    End Select
    ' Change the dimension and tolerance precision
    dimObj.TolerancePrecision = newPrecision
    dimObj.PrimaryUnitsPrecision = newPrecision
    ' Read back and display the dimension and dimension tolerance precision
    newPrecision = dimObj.PrimaryUnitsPrecision
    MsgBox "The precision has been set to " & newPrecision & " decimal places"
(defun c:Example_PrimaryUnitsPrecision()
    ;; uses PrimaryUnitsPrecision to allow the user to change
    ;; the number of decimal places displayed for the primary units and tolerance
    ;; units of the dimension.
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5.12345678 5 0)
    ;; Enable and setup tolerance display
    (vla-put-ToleranceDisplay dimObj acTolSymmetrical)
    (vla-put-ToleranceLowerLimit dimObj -0.0001)
    (vla-put-ToleranceUpperLimit dimObj 0.005)
    (vla-ZoomAll acadObj)
    ;; Store old precision value as default for input box
    (setq oldPrecision (vla-get-PrimaryUnitsPrecision dimObj))
    ;; Allow the user to change the precision for the dimension and dimension tolerance
    (setq newPrecision (vla-GetInteger (vla-get-Utility doc) "\nEnter a new precision for the dimension and tolerances (0 - 8): "))
    (setq newPrecision (cond
                           ((= 0 newPrecision) acDimPrecisionZero)
                           ((= 1 newPrecision) acDimPrecisionOne)
                           ((= 2 newPrecision) acDimPrecisionTwo)
                           ((= 3 newPrecision) acDimPrecisionThree)
                           ((= 4 newPrecision) acDimPrecisionFour)
                           ((= 5 newPrecision) acDimPrecisionFive)
                           ((= 6 newPrecision) acDimPrecisionSix)
                           ((= 7 newPrecision) acDimPrecisionSeven)
                           ((= 8 newPrecision) acDimPrecisionEight)
                           (nil)
    ;; Change the dimension and tolerance precision
    (if (/= newPrecision nil)
        (progn
            (vla-put-TolerancePrecision dimObj newPrecision)
            (vla-put-PrimaryUnitsPrecision dimObj newPrecision)
            ;; Read back and display the dimension and dimension tolerance precision
            (setq newPrecision (vla-get-PrimaryUnitsPrecision dimObj))
            (alert (strcat "The precision has been set to " (itoa newPrecision) " decimal places"))
        (alert "The precision has not been changed.")
GMT+8, 2026-11-15 11:43
