PlotWithPlotStyles 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 821| 评论: 0|原作者: admin|来自: AutoCAD
指定是否使用应用于对象并在打印样式表中定义的打印样式进行打印。
object.PlotWithPlotStyles
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:布尔
  • True:打印时使用应用于对象的打印样式。
  • False:打印时不要使用应用于对象的打印样式。
该特性等效于 AutoCAD 中的“使用打印样式打印”选项。PlotWithPlotStyles
Sub Example_PlotWithPlotStyles()
    ' This example reads and changes the PlotWithPlotStyles
    ' value, and shows a plot preview so the user can see the change.
    Dim ACADLayout As ACADLayout
    Dim originalValue As Boolean
    ' Get the layout object
    Set ACADLayout = ThisDrawing.ActiveLayout
    originalValue = ACADLayout.PlotWithPlotStyles
    MsgBox "The PlotWithPlotStyles value is set to: " & originalValue
    ' Modify the PlotWithPlotStyles preference by changing the value
    ACADLayout.PlotWithPlotStyles = Not ACADLayout.PlotWithPlotStyles
    MsgBox "The PlotWithPlotStyles preference has been set to: " & ACADLayout.PlotWithPlotStyles
    ThisDrawing.ActiveLayout.ConfigName = "DWF6 ePlot.pc3"
    'Show plot preview
    ThisDrawing.Plot.DisplayPlotPreview acFullPreview
(defun c:Example_PlotWithPlotStyles()
    ;; This example reads and changes the PlotWithPlotStyles
    ;; value, and shows a plot preview so the user can see the change.
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    (setq originalValue (vla-get-PlotWithPlotStyles ACADLayout))
    (alert (strcat "The PlotWithPlotStyles value is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PlotWithPlotStyles preference by changing the value
    (vla-put-PlotWithPlotStyles ACADLayout (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PlotWithPlotStyles ACADLayout))
    (alert (strcat "The PlotWithPlotStyles preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;; Set an output device current
    (if (= (strcase (vla-get-ConfigName (vla-get-ActiveLayout doc))) "NONE")
        (vla-put-ConfigName (vla-get-ActiveLayout doc) "DWF6 ePlot.pc3")
    ;; Show plot preview
    (vla-DisplayPlotPreview (vla-get-Plot doc) acFullPreview)
GMT+8, 2026-11-15 12:38
