ObjectSnapMode 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 771| 评论: 0|原作者: admin|来自: AutoCAD
指定对象捕捉模式的设置。
object.ObjectSnapMode
类别: 文档
此属性应用于的对象。
只读:不
类型:布尔
  • True:捕捉模式已打开。
  • False:捕捉模式已关闭。
Sub Example_ObjectSnapMode()
    ' This example toggles the setting of the Object Snap Mode.
    Dim currObjSnapMode As Boolean
    ' Get the current ObjectSnapMode value
    currObjSnapMode = ThisDrawing.ObjectSnapMode
    MsgBox "The object snap mode is currently " & IIf(ThisDrawing.ObjectSnapMode, "on.", "off."), , "ObjectSnapMode Example"
    ' Change the default ObjectSnapMode value
    ThisDrawing.ObjectSnapMode = Not (currObjSnapMode)
    MsgBox "The object snap mode is now " & IIf(ThisDrawing.ObjectSnapMode, "on.", "off."), , "ObjectSnapMode Example"
(defun c:Example_ObjectSnapMode()
    ;; This example toggles the setting of the Object Snap Mode.
    ;; Get the current ObjectSnapMode value
    (setq currObjSnapMode (vla-get-ObjectSnapMode doc))
    (alert (strcat "The object snap mode is currently " (if (= (vla-get-ObjectSnapMode doc) :vlax-true) "on." "off.")))
    ;; Change the default ObjectSnapMode value
    (vla-put-ObjectSnapMode doc (if (= (vla-get-ObjectSnapMode doc) :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The object snap mode is now " (if (= (vla-get-ObjectSnapMode doc) :vlax-true) "on." "off.")))
GMT+8, 2026-11-15 12:35
