NameNoMnemonic 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 966| 评论: 0|原作者: admin|来自: AutoCAD
指定不带下划线助记符的弹出菜单的名称。
object.NameNoMnemonic
类型:PopupMenu
此属性应用于的对象。
只读:是的
类型:字符串
不带下划线助记符的弹出菜单名称。
Sub Example_NameNoMnemonic()
    ' This example iterates through the menus collection and
    ' displays the Name and NameNoMnemonic property for each menu.
    ' Note that depending on how many menus are currently loaded, the
    ' menuStatus string may not be displayed in full.
    Dim currMenu As AcadPopupMenu
    Dim menuStatus As String
    menuStatus = ""
    For Each currMenu In ThisDrawing.Application.MenuGroups.Item(0).Menus
        menuStatus = menuStatus & currMenu.name & " -- " & currMenu.NameNoMnemonic & vbCrLf
    Next currMenu
    MsgBox menuStatus
(defun c:Example_NameNoMnemonic()
    ;; This example iterates through the menus collection and
    ;; displays the Name and NameNoMnemonic property for each menu.
    ;; Note that depending on how many menus are currently loaded, the
    ;; menuStatus string may not be displayed in full.
    (setq menuStatus "")
    (vlax-for currMenu (vla-get-Menus (vla-Item (vla-get-MenuGroups acadObj) 0))
        (setq menuStatus (strcat menuStatus (vla-get-Name currMenu) " -- " (vla-get-NameNoMnemonic currMenu) "\n"))
    (alert menuStatus)
GMT+8, 2026-11-15 12:19
