MSpace 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 1064| 评论: 0|原作者: admin|来自: AutoCAD
MSpace 属性 (ActiveX)
允许从浮动图纸空间视口编辑模型。
object.MSpace
类别: 文档
此属性应用于的对象。
只读:不
类型:布尔
  • True:允许编辑模型。
  • False:不允许编辑模型。
AutoCAD 在模型空间或图纸空间中运行。使用模型空间进行绘图和设计工作,并创建 2D 工程图或 3D 模型。使用图纸空间创建图形的完成布局以进行打印或打印。
注意:在使用该属性之前,必须将该属性设置为 ,并且该属性必须打开对象的显示控件。MSpaceActiveSpaceacPaperSpacePViewportDisplay
Sub Example_MSpace()
    ' This example creates a new paper space viewport.
    ' It then toggles the ability to edit in model space using
    ' the MSpace property.
    Dim pviewportObj As AcadPViewport
    Dim center(0 To 2) As Double
    Dim width As Double
    Dim height As Double
    ' Define the paper space viewport
    center(0) = 3: center(1) = 3: center(2) = 0
    width = 40
    height = 40
    ' Change from model space to paperspace
    ThisDrawing.ActiveSpace = acPaperSpace
    ' Create the paper space viewport
    Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
    pviewportObj.DISPLAY True
    ThisDrawing.mspace = True
    ThisDrawing.ActivePViewport = pviewportObj
    ' Find the current MSpace value
    MsgBox "The ability to edit model space from this PViewport is " & IIf(ThisDrawing.mspace, "on.", "off."), , "MSpace Example"
    ' Toggle the setting of MSpace
    ThisDrawing.mspace = False
    MsgBox "The ability to edit model space from this PViewport is now " & IIf(ThisDrawing.mspace, "on.", "off."), , "MSpace Example"
(defun c:Example_MSpace()
    ;; This example creates a new paper space viewport.
    ;; It then toggles the ability to edit in model space using
    ;; the MSpace property.
    ;; Define the paper space viewport
    (setq center (vlax-3d-point 3 3 0)
          width 40
          height 40)
    ;; Change from model space to paperspace
    (vla-put-ActiveSpace doc acPaperSpace)
    ;; Create the paper space viewport
    (setq paperSpace (vla-get-PaperSpace doc))
    (setq pviewportObj (vla-AddPViewport paperSpace center width height))
    (vla-Display pviewportObj :vlax-true)
    (vla-put-MSpace doc :vlax-true)
    (vla-put-ActivePViewport doc pviewportObj)
    ;; Find the current MSpace value
    (alert (strcat "The ability to edit model space from this PViewport is " (if (= (vla-get-MSpace doc) :vlax-true) "on." "off.")))
    ;; Toggle the setting of MSpace
    (vla-put-MSpace doc :vlax-false)
    (alert (strcat "The ability to edit model space from this PViewport is now " (if (= (vla-get-MSpace doc) :vlax-true) "on." "off.")))
GMT+8, 2026-11-15 12:29
