Mode 属性 (ActiveX)
指定属性定义的模式。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acAttributeMode
注意:此属性的值存储在 AFLAGS 系统变量中。
例子VBA: Sub Example_Mode()
' This example creates an attribute definition in model space.
' It then queries the initial value of the Mode property,
' changes that value, and finally resets the value.
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
' Define the attribute definition
height = 1#
mode = acAttributeModeVerify
prompt = "New Prompt"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
tag = "New_Tag"
value = "New Value"
' Create the attribute definition object in model space
Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
ZoomAll
' Return the current field length of the attribute
Dim currMode As Integer
Dim constant As String
currMode = attributeObj.mode
GoSub GETCONSTANT
MsgBox "The Mode of the attribute is " & constant, vbInformation, "Mode Example"
' Change the field length
attributeObj.mode = acAttributeModeInvisible
GoSub GETCONSTANT
attributeObj.Update
MsgBox "The new Mode of the attribute is " & constant, vbInformation, "Mode Example"
' Reset the field length to the original value
attributeObj.mode = currMode
GoSub GETCONSTANT
attributeObj.Update
MsgBox "The Mode of the attribute is reset to " & constant, vbInformation, "Mode Example"
Exit Sub
GETCONSTANT:
' Get the constant that corresponds to the current mode
constant = Choose(attributeObj.mode, "acAttributeModeInvisible", "acAttributeModeConstant", "", "acAttributeModeVerify", "", "", "", "acAttributeModePreset")
Return
可视化 LISP: (vl-load-com)
(defun c:Example_Mode()
;; This example creates an attribute definition in model space.
;; It then queries the initial value of the Mode property,
;; changes that value, and finally resets the value.
;; Define the attribute definition
(setq insertionPoint (vlax-3d-point 5 5 0)
attHeight 1
attMode acAttributeModeVerify
attPrompt "New Prompt"
attTag "NEW_TAG"
attValue "New Value")
;; Create the attribute definition object in model space
(setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
(vla-ZoomAll acadObj)
;; Return the current field length of the attribute
(setq currMode (vla-get-Mode attributeObj))
;; Get the constant that corresponds to the current mode
(setq constant (cond
((= (vla-get-Mode attributeObj) 0) "acAttributeModeNormal")
((= (vla-get-Mode attributeObj) 1) "acAttributeModeInvisible")
((= (vla-get-Mode attributeObj) 2) "acAttributeModeConstant")
((= (vla-get-Mode attributeObj) 4) "acAttributeModeVerify")
((= (vla-get-Mode attributeObj) 8) "acAttributeModePreset")
(alert (strcat "The Mode of the attribute is " constant))
;; Change the field length
(vla-put-Mode attributeObj acAttributeModeInvisible)
(vla-Update attributeObj)
(alert (strcat "The new Mode of the attribute is " constant))
;; Reset the field length to the original value
(vla-put-Mode attributeObj currMode)
(alert (strcat "The Mode of the attribute is reset to " constant))
GMT+8, 2026-11-15 12:33
