LogFileOn 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 700| 评论: 0|原作者: admin|来自: AutoCAD
指定是否将文本窗口的内容写入日志文件。
object.LogFileOn
类型:PreferencesOpenSave
此属性应用于的对象。
只读:不
类型:布尔
  • True:日志文件已打开。
  • False:日志文件已关闭。
此属性的初始值为 。True
日志文件将文本窗口的内容记录在文本文件中。使用该属性指定日志文件的名称。LogFilePath
注意:此属性的值存储在 LOGFILEMODE 系统变量中。
Sub Example_LogFileOn()
    ' LogFileOn. It then changes the value, and finally
    Dim currLogFileOn As Boolean
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current LogFileOn value
    currLogFileOn = preferences.OpenSave.LogFileOn
    MsgBox "The current value for LogFileOn is " & preferences.OpenSave.LogFileOn, vbInformation, "LogFileOn Example"
    ' Change the value for LogFileOn
    preferences.OpenSave.LogFileOn = Not (currLogFileOn)
    MsgBox "The new value for LogFileOn is " & preferences.OpenSave.LogFileOn, vbInformation, "LogFileOn Example"
    ' Reset LogFileOn to its original value
    preferences.OpenSave.LogFileOn = currLogFileOn
    MsgBox "The LogFileOn value is reset to " & preferences.OpenSave.LogFileOn, vbInformation, "LogFileOn Example"
(defun c:Example_LogFileOn()
    ;; LogFileOn. It then changes the value, and finally
    ;; Retrieve the current LogFileOn value
    (setq currLogFileOn (vla-get-LogFileOn (vla-get-OpenSave preferences)))
    (alert (strcat "The current value for LogFileOn is " (if (= currLogFileOn :vlax-true) "True" "False")))
    ;; Change the value for LogFileOn
    (vla-put-LogFileOn (vla-get-OpenSave preferences) (if (= currLogFileOn :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The new value for LogFileOn is " (if (= (vla-get-LogFileOn (vla-get-OpenSave preferences)) :vlax-true) "True" "False")))
    ;; Reset LogFileOn to its original value
    (vla-put-LogFileOn (vla-get-OpenSave preferences) currLogFileOn)
    (alert (strcat "The LogFileOn value is reset to " (if (= (vla-get-LogFileOn (vla-get-OpenSave preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-11-15 12:48
