LineSpacingDistance 属性 (ActiveX)
指定多行文本的间距。 支持的平台:仅限 Windows 属性值只读:不 类型:双 多行文本的间距。 言论MText:此属性中包含的值是“属性”选项板中的“线空间距离”属性。 例子VBA: Sub Example_LineSpacingDistance()
' This example creates an MText object, displays the value of the LineSpacingDistance property,
' changes the value of the property, and then resets the value to the original value.
Dim MTextObj As AcadMText
Dim width As Double
Dim text As String
Dim CurrentDistance As Double
Dim corner(0 To 2) As Double
corner(0) = 0
corner(1) = 10
corner(2) = 0
width = 10
text = "This is the text for the MText object"
' Creates the MText Object
Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
ZoomAll
' Find the current LineSpacingDistance
CurrentDistance = MTextObj.LineSpacingDistance
MsgBox "The LineSpacingDistance for the MText object is: " & CurrentDistance
' Change the LineSpacingDistance
MTextObj.LineSpacingDistance = 0.7
MsgBox "The LineSpacingDistance for the MText object is: " & MTextObj.LineSpacingDistance
' Reset the LineSpacingDistance
MTextObj.LineSpacingDistance = CurrentDistance
可视化 LISP: (vl-load-com)
(defun c:Example_LineSpacingDistance()
;; This example creates an MText object, displays the value of the LineSpacingDistance property,
;; changes the value of the property, and then resets the value to the original value.
(setq corner (vlax-3d-point 0 10 0)
width 10
text "This is the text for the MText object")
;; Creates the MText Object
(setq MTextObj (vla-AddMText modelSpace corner width text))
(vla-ZoomAll acadObj)
;; Find the current LineSpacingDistance
(setq CurrentDistance (vla-get-LineSpacingDistance MTextObj))
(alert (strcat "The LineSpacingDistance for the MText object is: " (rtos CurrentDistance 2)))
;; Change the LineSpacingDistance
(vla-put-LineSpacingDistance MTextObj 0.7)
(alert (strcat "The LineSpacingDistance for the MText object is: " (rtos (vla-get-LineSpacingDistance MTextObj) 2)))
;; Reset the LineSpacingDistance
(vla-put-LineSpacingDistance MTextObj CurrentDistance)
GMT+8, 2026-11-15 13:55
