LinearScaleFactor 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 571| 评论: 0|原作者: admin|来自: AutoCAD
指定线性尺寸测量的全局比例因子。
object.LinearScaleFactor
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:双
大于 0.0 的实数。
此属性的初始值为 1.0000。
当指定负值时,该因子仅应用于图纸空间。要应用的纸张空间系数是此属性的绝对值。LinearScaleFactor
注意:此属性将覆盖给定维度的 DIMLFAC 系统变量的值。
Sub Example_LinearScaleFactor()
    ' turns on the tolerance display for the new dimension.  The LinearScaleFactor
    ' of the tolerance is then read and modified.
    ' * Note the change in the text of the dimension after the modification.
    Dim dimObj As AcadDimAligned
    Dim newText As AcadTextStyle
    Dim CurrentScale As Integer
    ' Define the dimension
    point1(0) = 1: point1(1) = 10: point1(2) = 0
    point2(0) = 10: point2(1) = 10: point2(2) = 0
    ' Turn on the tolerance display
    dimObj.ToleranceDisplay = acTolSymmetrical
    ' Display current scale factor
    MsgBox dimObj.LinearScaleFactor
    ' Change current scale factor
    dimObj.LinearScaleFactor = 10#      ' Multiply by ten
    ' Display new scale factor
(defun c:Example_LinearScaleFactor()
    ;; turns on the tolerance display for the new dimension.  The LinearScaleFactor
    ;; of the tolerance is then read and modified.
    ;; * Note the change in the text of the dimension after the modification.
    ;; Define the dimension
    (setq point1 (vlax-3d-point 1 10 0)
          point2 (vlax-3d-point 10 10 0)
    ;; Turn on the tolerance display
    (vla-put-ToleranceDisplay dimObj acTolSymmetrical)
    (vla-ZoomAll acadObj)
    ;; Display current scale factor
    (alert (rtos (vla-get-LinearScaleFactor dimObj) 2))
    ;; Change current scale factor
    (vla-put-LinearScaleFactor dimObj 10)      ;; Multiply by ten
    ;; Display new scale factor
GMT+8, 2026-11-15 14:41
