LensLength 属性 (ActiveX)
指定透视视图中使用的镜头长度。 支持的平台:仅限 Windows 属性值只读:不 类型:双 镜头的长度(以毫米为单位)。 言论
注意:此属性的值存储在 LENSLENGTH 系统变量中。
例子VBA: Sub Example_LensLength()
' This example creates a new paper space viewport.
' It then displays the lens length of the viewport.
Dim pviewportObj As AcadPViewport
Dim center(0 To 2) As Double
Dim width As Double
Dim height As Double
' Define the paper space viewport
center(0) = 3: center(1) = 3: center(2) = 0
width = 40
height = 40
' Change from model space to paper space
ThisDrawing.ActiveSpace = acPaperSpace
' Create the paper space viewport
Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
pviewportObj.DISPLAY True
ThisDrawing.mspace = True
ThisDrawing.ActivePViewport = pviewportObj
' Find the Lens Length for the viewport
Dim lenslgnth As Double
lenslgnth = pviewportObj.LensLength
MsgBox "The lens length of the paperspace viewport is " & pviewportObj.LensLength, , "LensLength Example"
可视化 LISP: (vl-load-com)
(defun c:Example_LensLength()
;; This example creates a new paper space viewport.
;; It then displays the lens length of the viewport.
;; Define the paper space viewport
(setq center (vlax-3d-point 3 3 0)
width 40
height 40)
;; Change from model space to paper space
(vla-put-ActiveSpace doc acPaperSpace)
;; Create the paper space viewport
(setq paperSpace (vla-get-PaperSpace doc))
(setq pviewportObj (vla-AddPViewport paperSpace center width height))
(vla-Display pviewportObj :vlax-true)
(vla-put-MSpace doc :vlax-true)
(vla-put-ActivePViewport doc pviewportObj)
;; Find the Lens Length for the viewport
(setq lenslgnth (vla-get-LensLength pviewportObj))
(alert (strcat "The lens length of the paperspace viewport is " (rtos lenslgnth 2)))
GMT+8, 2026-11-15 13:40
