Layer 属性 (ActiveX)
指定对象的图层。 支持的平台:仅限 Windows 签名VBA: object.Layer 属性值只读:不;除了只写对象Group 类型:字符串 图层的名称。 言论所有对象都有一个关联的层。文档始终包含至少一个图层(图层 0)。与线型一样,您可以为对象指定图层。如果未指定图层,则当前活动图层将用于新对象。如果为对象指定了图层,则忽略当前活动图层。使用该属性可设置或查询当前活动图层。ActiveLayer 每个图层都有关联的属性,可以通过对象进行设置和查询。Layer 例子VBA: Sub Example_Layer()
' This example creates a new layer named "ABC" (colored blue).
' It then creates a circle and assigns it to layer "ABC"
' Create new layer
Dim layerObj As AcadLayer
Set layerObj = ThisDrawing.Layers.Add("ABC")
Dim color As AcadAcCmColor
Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
Call color.SetRGB(80, 100, 244)
layerObj.TrueColor = color
' Create Circle
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 3: center(1) = 3: center(2) = 0
radius = 1.5
Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
ZoomAll
MsgBox "The circle has been created on layer " & circleObj.Layer, , "Layer Example"
' Set the layer of new circle to "ABC"
circleObj.Layer = "ABC"
' Refresh view
ThisDrawing.Regen (True)
MsgBox "The circle is now on layer " & circleObj.Layer, , "Layer Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Layer()
;; This example creates a new layer named "ABC" (colored blue).
;; It then creates a circle and assigns it to layer "ABC"
;; Create new layer
(setq layerObj (vla-Add (vla-get-Layers doc) "ABC"))
(setq color (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
(vla-SetRGB color 80 100 244)
(vla-put-TrueColor layerObj color)
;; Create Circle
(setq center (vlax-3d-point 3 3 0)
radius 1.5)
(setq circleObj (vla-AddCircle modelSpace center radius))
(vla-ZoomAll acadObj)
(alert (strcat "The circle has been created on layer " (vla-get-Layer circleObj)))
;; Set the layer of new circle to "ABC"
(vla-put-Layer circleObj "ABC")
;; Refresh view
(vla-Regen doc :vlax-true)
(alert (strcat "The circle is now on layer " (vla-get-Layer circleObj)))
(vlax-release-object color)
GMT+8, 2026-11-15 11:40
