KeyboardAccelerator 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 1003| 评论: 0|原作者: admin|来自: AutoCAD
指定 Windows 标准键盘或 AutoCAD 经典键盘。
object.KeyboardAccelerator
类型:PreferencesUser
此属性应用于的对象。
只读:不
类型:枚举acKeyboardAccelerator
  • acPreferenceClassic:使用 AutoCAD 经典键盘。
  • acPreferenceCustom:使用 Windows 标准键盘。
Sub Example_KeyboardAccelerator()
    ' KeyboardAccelerator. It then changes the value, and finally
    Dim currKeyboardAccelerator As Integer
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current KeyboardAccelerator value
    currKeyboardAccelerator = preferences.User.KeyboardAccelerator
    MsgBox "The current value for KeyboardAccelerator is " & currKeyboardAccelerator, vbInformation, "KeyboardAccelerator Example"
    ' Change the value for KeyboardAccelerator
    If currKeyboardAccelerator = acPreferenceClassic Then
        preferences.User.KeyboardAccelerator = acPreferenceCustom
    Else
        preferences.User.KeyboardAccelerator = acPreferenceClassic
    End If
    MsgBox "The new value for KeyboardAccelerator is " & preferences.User.KeyboardAccelerator, vbInformation, "KeyboardAccelerator Example"
    ' Reset KeyboardAccelerator to its original value
    preferences.User.KeyboardAccelerator = currKeyboardAccelerator
    MsgBox "The KeyboardAccelerator value is reset to " & preferences.User.KeyboardAccelerator, vbInformation, "KeyboardAccelerator Example"
(defun c:Example_KeyboardAccelerator()
    ;; KeyboardAccelerator. It then changes the value, and finally
    ;; Retrieve the current KeyboardAccelerator value
    (setq currKeyboardAccelerator (vla-get-KeyboardAccelerator (vla-get-User preferences)))
    (alert (strcat "The current value for KeyboardAccelerator is " (if (= currKeyboardAccelerator acPreferenceClassic) "Classic" "Custom")))
    ;; Change the value for KeyboardAccelerator
        (vla-put-KeyboardAccelerator (vla-get-User preferences) acPreferenceCustom)
        (vla-put-KeyboardAccelerator (vla-get-User preferences) acPreferenceClassic)
    (alert (strcat "The new value for KeyboardAccelerator is " (if (= (vla-get-KeyboardAccelerator (vla-get-User preferences)) acPreferenceClassic) "Classic" "Custom")))
    ;; Reset KeyboardAccelerator to its original value
    (vla-put-KeyboardAccelerator (vla-get-User preferences) currKeyboardAccelerator)
    (alert (strcat "The KeyboardAccelerator value is reset to " (if (= (vla-get-KeyboardAccelerator (vla-get-User preferences)) acPreferenceClassic) "Classic" "Custom")))
GMT+8, 2026-11-15 12:47
