Flyout 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 814| 评论: 0|原作者: admin|来自: AutoCAD
Flyout 属性 (ActiveX)
获取与浮出控件工具栏项关联的工具栏。
object.Flyout
类型:ToolbarItem
此属性应用于的对象。
只读:是的
类型:工具栏
包含工具栏项的工具栏。
Sub Example_Flyout()
    ' This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
    ' It then creates a new Toolbar(TestMenu) with a Toolbar button that will act
    ' as a flyout.  The examples sets the Flyout menu to an existing Toolbar menu.
    ' The Toolbar will automatically be displayed and will display the UCS menu
    ' as a flyout.
    Dim currMenuGroup As acadMenuGroup
    Dim newToolBar As AcadToolbar, newToolBarFlyoutButton As AcadToolbarItem
    On Error GoTo ERRORTRAP
    ' Use MenuGroups property to obtain reference to main AutoCAD menu
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item("ACAD")
    ' Create a new Toolbar in this group
    Set newToolBar = currMenuGroup.Toolbars.Add("TestMenu")
    ' Add new button to TestMenu that will link to the Flyout menu
    ' * NOTE: Set the macro name to the name of the flyout toolbar because
    ' setting it to an empty string causes an error.  The paremeter
    ' is actually ignored when the style is flyout, but must have any value other than "".
    Set newToolBarFlyoutButton = newToolBar.AddToolbarButton(newToolBar.count + 1, "Flyout", "Flyout", "UCS", True)
    ' Link the existing toolbar "UCS" as the flyout for the new toolbar button
    ' * NOTE: To change the flyout, simply change the MenuGroup and Toolbar name below
    newToolBarFlyoutButton.AttachToolbarToFlyout "ACAD", "UCS"
    MsgBox "The flyout attached to the Test menu is " & newToolBarFlyoutButton.Flyout.name
    Exit Sub
ERRORTRAP:
    MsgBox "The following error has occurred: " & Err.Description
(defun c:Example_Flyout()
    ;; This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
    ;; It then creates a new Toolbar(TestMenu) with a Toolbar button that will act
    ;; as a flyout.  The examples sets the Flyout menu to an existing Toolbar menu.
    ;; The Toolbar will automatically be displayed and will display the UCS menu
    ;; as a flyout.
    (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
    ;; Create a new Toolbar in this group
    (setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "TestToolbar"))
    ;; Add new button to TestMenu that will link to the Flyout menu
    ;; * NOTE: Set the macro name to the name of the flyout toolbar because
    ;; setting it to an empty string causes an error.  The paremeter
    ;; is actually ignored when the style is flyout, but must have any value other than "".
    (setq newToolBarFlyoutButton (vla-AddToolbarButton newToolBar (1+ (vla-get-Count newToolBar)) "Flyout" "Flyout" "UCS" :vlax-true))
    ;; Link the existing toolbar "UCS" as the flyout for the new toolbar button
    ;; * NOTE: To change the flyout, simply change the MenuGroup and Toolbar name below
    (vla-AttachToolbarToFlyout newToolBarFlyoutButton "ACAD" "UCS")
    (alert (strcat "The flyout attached to the Test menu is " (vla-get-Name (vla-get-Flyout newToolBarFlyoutButton))))
GMT+8, 2026-11-15 12:45
