ExtensionLineWeight 属性 (ActiveX)
指定延长线的线宽。 支持的平台:仅限 Windows 签名VBA: object.ExtensionLineWeight
属性值只读:不 类型:枚举acLineWeight
言论此属性的初始值为 。acLnWtByBlock 仅当属性设置为 时,线宽设置才可见。LineweightDisplayTrue
注意:此属性将覆盖给定维度的 DIMLWE 系统变量的值。
例子VBA: Sub Example_ExtensionLineWeight()
' This example creates a Dim3PointAngular object in model space
' and changes the extension lineweight to a thicker value
' using the ExtensionLineWeight property
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
Dim oldLWSetting As Boolean
Dim CurrentSetting As String
' Turn on lineweight display to see the changes
oldLWSetting = ThisDrawing.preferences.LineWeightDisplay
ThisDrawing.preferences.LineWeightDisplay = True
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Read and display current extension lineweight
CurrentSetting = DimPointAngularObj.ExtensionLineWeight
Select Case CurrentSetting
Case acLnWtByLayer: CurrentSetting = "ByLayer"
Case acLnWtByBlock: CurrentSetting = "ByBlock"
Case acLnWtByLwDefault: CurrentSetting = "ByDefault"
Case Else
End Select
MsgBox "The extension lineweight for this object is currently set to: " & CurrentSetting
' Change the extension lineweight
DimPointAngularObj.ExtensionLineWeight = acLnWt100
MsgBox "The extension line weight for this object is now set to: " & DimPointAngularObj.ExtensionLineWeight
' Return previous lineweight setting
ThisDrawing.preferences.LineWeightDisplay = oldLWSetting
可视化 LISP: (vl-load-com)
(defun c:Example_ExtensionLineWeight()
;; This example creates a Dim3PointAngular object in model space
;; and changes the extension lineweight to a thicker value
;; using the ExtensionLineWeight property
(setq preferences (vla-get-Preferences doc))
;; Turn on lineweight display to see the changes
(setq oldLWSetting (vla-get-LineWeightDisplay preferences))
(vla-put-LineWeightDisplay preferences :vlax-true)
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Read and display current extension lineweight
(setq CurrentSetting (vla-get-ExtensionLineWeight DimPointAngularObj))
(cond
((= acLnWtByLayer CurrentSetting)(setq CurrentSetting "ByLayer"))
((= acLnWtByBlock CurrentSetting)(setq CurrentSetting "ByBlock"))
((= acLnWtByLwDefault CurrentSetting)(setq CurrentSetting "ByDefault"))
(setq CurrentSetting (itoa CurrentSetting))
(alert (strcat "The extension lineweight for this object is currently set to: " CurrentSetting))
;; Change the extension lineweight
(vla-put-ExtensionLineWeight DimPointAngularObj acLnWt100)
(alert (strcat "The extension line weight for this object is now set to: " (itoa (vla-get-ExtensionLineWeight DimPointAngularObj))))
;; Return previous lineweight setting
(vla-put-ExtensionLineWeight DimPointAngularObj oldLWSetting)
GMT+8, 2026-11-15 11:49
