DisplayGripsWithinBlocks 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 808| 评论: 0|原作者: admin|来自: AutoCAD
控制块内夹点的分配。
object.DisplayGripsWithinBlocks
类型:首选项选择
此属性应用于的对象。
只读:不
类型:布尔
  • True:将夹点分配给块内的对象。
  • False:仅将夹持分配给块的插入点。
此属性的初始值为 。False
注意:此属性的值存储在 GRIPBLOCK 系统变量中。
Sub Example_DisplayGripsWithinBlocks()
    ' This example reads and modifies the preference value that controls
    ' the assignment of grips within blocks.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSelection
    ' Get the selection preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Selection
    originalValue = ACADPref.DisplayGripsWithinBlocks
    MsgBox "The DisplayGripsWithinBlocks preference is set to: " & originalValue
    ' Modify the DisplayGripsWithinBlocks preference by toggling the value
    ACADPref.DisplayGripsWithinBlocks = Not (originalValue)
    newValue = ACADPref.DisplayGripsWithinBlocks
    MsgBox "The DisplayGripsWithinBlocks preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.DisplayGripsWithinBlocks = originalValue
    MsgBox "The DisplayGripsWithinBlocks preference was reset back to: " & originalValue
(defun c:Example_DisplayGripsWithinBlocks()
    ;; This example reads and modifies the preference value that controls
    ;; the assignment of grips within blocks.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the selection preferences object
    (setq ACADPref (vla-get-Selection preferences))
    (setq originalValue (vla-get-DisplayGripsWithinBlocks ACADPref))
    (alert (strcat "The DisplayGripsWithinBlocks preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the DisplayGripsWithinBlocks preference by toggling the value
    (vla-put-DisplayGripsWithinBlocks ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-DisplayGripsWithinBlocks ACADPref))
    (alert (strcat "The DisplayGripsWithinBlocks preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-DisplayGripsWithinBlocks ACADPref originalValue)
    (alert (strcat "The DisplayGripsWithinBlocks preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-15 12:33
