DimLine1Suppress 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 706| 评论: 0|原作者: admin|来自: AutoCAD
指定第一条尺寸线的隐含。
object.DimLine1Suppress
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:隐含第一条维度线。
  • False:不要隐含第一维度线。
此属性的初始值为 。False
当此属性设置为 时,将禁止显示第一条延长线和文本之间的尺寸线和箭头。True
注意:此属性将覆盖给定维度的 DIMSD1 系统变量的值。
Sub Example_DimensionLine1Suppress()
    ' This example creates a Dim3PointAngular object in model space
    ' and suppresses the dimension lines using the DimensionLine1Suppress
    ' and DimensionLine2Suppress properties
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    Dim Line1Suppressed As String, Line2Suppressed As String
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Read and display current line suppression information
    Line1Suppressed = IIf(DimPointAngularObj.DimLine1Suppress, "is suppressed", "is not suppressed")
    Line2Suppressed = IIf(DimPointAngularObj.DimLine2Suppress, "is suppressed", "is not suppressed")
    MsgBox "Line one of the dimension " & Line1Suppressed & vbCrLf & _
           "Line two of the dimension " & Line2Suppressed
    ' Suppress line one of the dimension
    DimPointAngularObj.DimLine1Suppress = True
    MsgBox "Line one of the dimension is now suppressed"
    ' Suppress line two of the dimension
    DimPointAngularObj.DimLine2Suppress = True
    MsgBox "Line two of the dimension is now suppressed"
    ' Turn both dimension lines back on
    DimPointAngularObj.DimLine1Suppress = False
    DimPointAngularObj.DimLine2Suppress = False
    MsgBox "Both dimension lines are now visible again"
(defun c:Example_DimensionLine1Suppress()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and suppresses the dimension lines using the DimensionLine1Suppress
    ;; and DimensionLine2Suppress properties
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Read and display current line suppression information
    (setq Line1Suppressed (if (= (vla-get-DimLine1Suppress DimPointAngularObj) :vlax-true) "is suppressed" "is not suppressed"))
    (setq Line2Suppressed (if (= (vla-get-DimLine2Suppress DimPointAngularObj) :vlax-true) "is suppressed" "is not suppressed"))
    (alert (strcat "Line one of the dimension " Line1Suppressed
                   "\nLine two of the dimension " Line2Suppressed))
    ;; Suppress line one of the dimension
    (vla-put-DimLine1Suppress DimPointAngularObj :vlax-true)
    (alert "Line one of the dimension is now suppressed")
    ;; Suppress line two of the dimension
    (vla-put-DimLine2Suppress DimPointAngularObj :vlax-true)
    (alert "Line two of the dimension is now suppressed")
    ;; Turn both dimension lines back on
    (vla-put-DimLine1Suppress DimPointAngularObj :vlax-false)
    (vla-put-DimLine2Suppress DimPointAngularObj :vlax-false)
    (alert "Both dimension lines are now visible again")
GMT+8, 2026-11-15 13:32
