Diameter 属性 (ActiveX)
指定圆的直径。 支持的平台:仅限 Windows 属性值只读:不 类型:双 圆的直径。 言论没有其他评论。 例子VBA: Sub Example_Diameter()
' This example creates a Circle object in model space and
' returns the diameter of the new Circle
Dim circleObj As AcadCircle
Dim radius As Double
' Define the new Circle object
centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
radius = 5#
' Create the Circle object in model space
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
MsgBox "The diameter of the new Circle is: " & circleObj.Diameter
可视化 LISP: (vl-load-com)
(defun c:Example_Diameter()
;; This example creates a Circle object in model space and
;; returns the diameter of the new Circle
;; Define the new Circle object
(setq centerPoint (vlax-3d-point 0 0 0)
radius 5)
;; Create the Circle object in model space
(setq circleObj (vla-AddCircle modelSpace centerPoint radius))
(vla-ZoomAll acadObj)
(alert (strcat "The diameter of the new Circle is: " (rtos (vla-get-Diameter circleObj) 2)))
GMT+8, 2026-11-10 01:03
