Degree2 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 794| 评论: 0|原作者: admin|来自: AutoCAD
指定样条的多项式表示的度数。
object.Degree2
类型:样条曲线
此属性应用于的对象。
只读:不
类型:整数
介于 1 和 25 之间的整数(含 1 和 25)。
样条曲线的阶数等于样条曲线的度数加一 (+1)。
Sub Example_Degree()
    ' This example creates a spline and returns the degree
    ' of the spline's polynomial representation.
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ThisDrawing.Regen True
    MsgBox "The degree of this Spline's polynomial representation is: " & splineObj.Degree, vbInformation
(defun c:Example_Degree()
    ;; This example creates a spline and returns the degree
    ;; of the spline's polynomial representation.
    ;; Define the spline
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 0 0
				     5 5 0
				     10 0 0
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomExtents acadObj)
    (vla-Regen doc :vlax-true)
    (alert (strcat "The degree of this Spline's polynomial representation is: " (itoa (vla-get-Degree splineObj))))
GMT+8, 2026-11-15 11:40
