DefaultPlotStyleForObjects 属性 (ActiveX)
指定新创建对象的默认打印样式名称。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 有效条目包括 “ByLayer”、“ByBlock”、“Normal” 或当前加载的打印样式中的任何样式名称。 言论此属性的初始值为“ByLayer”。 仅当设置为 时,此属性才可用。PlotPolicyacPolicyNamed 使用该属性查找当前打印样式。DefaultPlotStyleTable
注意:此属性的值存储在 DEFLPLSTYLE 系统变量中。
例子VBA: Sub Example_DefaultPlotStyleForObjects()
' This example reads and modifies the preference value that controls
' the default plot style name for newly created objects.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesOutput
Dim originalPolicyValue As Variant, originalValue As Variant, newValue As Variant
' Get the output preferences object
Set ACADPref = ThisDrawing.Application.preferences.Output
' Set the default plot style to named plot styles
originalPolicyValue = ACADPref.PlotPolicy
ACADPref.PlotPolicy = acPolicyNamed
originalValue = ACADPref.DefaultPlotStyleForObjects
MsgBox "The DefaultPlotStyleForObjects preference is: " & originalValue
' Toggle and display the DefaultPlotStyleForObjects preference
If ACADPref.DefaultPlotStyleForObjects = "ByBlock" Then
ACADPref.DefaultPlotStyleForObjects = "Normal"
Else
End If
newValue = ACADPref.DefaultPlotStyleForObjects
MsgBox "The DefaultPlotStyleForObjects preference has been set to: " & newValue
' this preference in effect
ACADPref.DefaultPlotStyleForObjects = originalValue
MsgBox "The DefaultPlotStyleForObjects preference was reset back to: " & originalValue
ACADPref.PlotPolicy = originalPolicyValue
可视化 LISP: (vl-load-com)
(defun c:Example_DefaultPlotStyleForObjects()
;; This example reads and modifies the preference value that controls
;; the default plot style name for newly created objects.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the output preferences object
(setq ACADPref (vla-get-Output preferences))
;; Set the default plot style to named plot styles
(setq originalPolicyValue (vla-get-PlotPolicy ACADPref))
(vla-put-PlotPolicy ACADPref acPolicyNamed)
(setq originalValue (vla-get-DefaultPlotStyleForObjects ACADPref))
(alert (strcat "The DefaultPlotStyleForObjects preference is: " originalValue))
;; Toggle and display the DefaultPlotStyleForObjects preference
(if (= (vla-get-DefaultPlotStyleForObjects ACADPref) "ByBlock")
(vla-put-DefaultPlotStyleForObjects ACADPref "Normal")
(vla-put-DefaultPlotStyleForObjects ACADPref "ByBlock")
(setq newValue (vla-get-DefaultPlotStyleForObjects ACADPref))
(alert (strcat "The DefaultPlotStyleForObjects preference has been set to: " newValue))
;; this preference in effect
(vla-put-DefaultPlotStyleForObjects ACADPref originalValue)
(alert (strcat "The DefaultPlotStyleForObjects preference was reset back to: " originalValue))
(vla-put-PlotPolicy ACADPref originalPolicyValue)
GMT+8, 2026-11-15 12:36
