DefaultInternetURL 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 1047| 评论: 0|原作者: admin|来自: AutoCAD
指定默认 Internet 地址。
object.DefaultInternetURL
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
默认 Internet 地址。
注意:此属性的值存储在 INETLOCATION 系统变量中。
Sub Example_DefaultInternetURL()
    ' DefaultInternetURL. It then changes the value, and finally
    Dim currDefaultInternetURL As String
    Dim newDefaultInternetURL As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current DefaultInternetURL value
    currDefaultInternetURL = preferences.Files.DefaultInternetURL
    MsgBox "The current value for DefaultInternetURL is " & currDefaultInternetURL, vbInformation, "DefaultInternetURL Example"
    ' Change the value for DefaultInternetURL
    newDefaultInternetURL = "TestDefaultInternetURL"
    preferences.Files.DefaultInternetURL = newDefaultInternetURL
    MsgBox "The new value for DefaultInternetURL is " & newDefaultInternetURL, vbInformation, "DefaultInternetURL Example"
    ' Reset DefaultInternetURL to its original value
    preferences.Files.DefaultInternetURL = currDefaultInternetURL
    MsgBox "The DefaultInternetURL value is reset to " & currDefaultInternetURL, vbInformation, "DefaultInternetURL Example"
(defun c:Example_DefaultInternetURL()
    ;; DefaultInternetURL. It then changes the value, and finally
    ;; Retrieve the current DefaultInternetURL value
    (setq currDefaultInternetURL (vla-get-DefaultInternetURL (vla-get-Files preferences)))
    (alert (strcat "The current value for DefaultInternetURL is " currDefaultInternetURL))
    ;; Change the value for DefaultInternetURL
    (setq newDefaultInternetURL "TestDefaultInternetURL")
    (vla-put-DefaultInternetURL (vla-get-Files preferences) newDefaultInternetURL)
    (alert (strcat "The new value for DefaultInternetURL is " newDefaultInternetURL))
    ;; Reset DefaultInternetURL to its original value
    (vla-put-DefaultInternetURL (vla-get-Files preferences) currDefaultInternetURL)
    (alert (strcat "The DefaultInternetURL value is reset to " currDefaultInternetURL))
GMT+8, 2026-11-15 12:16
