CommandDisplayName 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 660| 评论: 0|原作者: admin|来自: AutoCAD
指定工具栏上按钮的显示命令名称。
object.CommandDisplayName
类型:ToolbarItem
此属性应用于的对象。
只读:不
类型:字符串
命令名称的字符串。
Sub Example_CommandDisplayName()
    Dim currMenuGroup As AcadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    Dim newToolBar As AcadToolbar
    Set newToolBar = currMenuGroup.Toolbars.Add("TestNewToolbar")
    ' Add a button to the new toolbar.
    Dim newButton1 As IAcadToolbarItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set newButton1 = newToolBar.AddToolbarButton("", "NewButton1", "Open a file.", openMacro)
    ' Display the toolbar
    newToolBar.Visible = True
    newButton1.CommandDisplayName = "Open a File"
    ' Read the current value of the Help string
    MsgBox "The current CommandDisplayName for the toolbar button is: " & newButton1.CommandDisplayName
    ' Change the value of the CommandDisplayName
    newButton1.CommandDisplayName = "Open File"
    ' Read the new value of the CommandDisplayName
    MsgBox "The new CommandDisplayName for the toolbar button is: " & newButton1.CommandDisplayName
(defun c:Example_CommandDisplayName()
    (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
    ;; Create the new toolbar
    (setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "TestToolbar"))
    ;; Assign the macro string the VB equivalent of "ESC ESC _open "
    (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
    (setq newButton1 (vla-AddToolbarButton newToolBar "" "NewButton1" "Open a file." openMacro))
    ;; Display the toolbar
    (vla-put-Visible newToolBar :vlax-true)
    (vla-put-CommandDisplayName newButton1 "Open a File")
    ;; Read the current value of the Help string
    (alert (strcat "The current CommandDisplayName for the toolbar button is: " (vla-get-CommandDisplayName newButton1)))
    ;; Change the value of the CommandDisplayName
    (vla-put-CommandDisplayName newButton1 "Open File")
    ;; Read the new value of the CommandDisplayName
    (alert (strcat "The new CommandDisplayName for the toolbar button is: " (vla-get-CommandDisplayName newButton1)))
GMT+8, 2026-11-15 12:15
