ColorIndex 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 1085| 评论: 0|原作者: admin|来自: AutoCAD
指定颜色索引。
object.ColorIndex
类型:AcCmColor
此属性应用于的对象。
只读:不
类型:枚举acColor
默认颜色名称为 。使用介于 0 到 256 之间的颜色索引号,或此处列出的常量之一:acByLayer
  • acByBlock
  • acByLayer(对对象无效)Layer
  • acRed
  • acYellow
  • acGreen
  • acCyan
  • acBlue
  • acMagenta
  • acWhite
Sub Example_ColorIndex()
    'This example draws a circle and
    'returns the closest color index.
    Dim col As AcadAcCmColor
    Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
    col.SetRGB 125, 175, 235
    Dim cir As AcadCircle
    Dim pt(0 To 2) As Double
    Set cir = ThisDrawing.modelSpace.AddCircle(pt, 2)
    cir.TrueColor = col
    ZoomAll
    Dim retCol As AcadAcCmColor
    Set retCol = cir.TrueColor
    If col.ColorMethod = AutoCAD.acColorMethodByRGB Then
    MsgBox "Closest ColorIndex=" & col.ColorIndex
    End If
(defun c:Example_ColorIndex()
    ;;This example draws a circle and
    ;;returns the closest color index.
    (setq col (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-SetRGB col 125 175 235)
    (setq pt (vlax-3d-point 0 0 0))
    (setq cir (vla-AddCircle modelSpace pt 2))
    (vla-put-TrueColor cir col)
    (vla-ZoomAll acadObj)
    (setq retCol (vla-get-TrueColor cir))
    (if (= (vla-get-ColorMethod col) acColorMethodByRGB)
        (alert (strcat "Closest ColorIndex=" (itoa (vla-get-ColorIndex col))))
    (vlax-release-object col)
GMT+8, 2026-11-15 11:55
