ClippingEnabled 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 838| 评论: 0|原作者: admin|来自: AutoCAD
启用或禁用剪裁边界。
object.ClippingEnabled
类型:DgnUnderlay、DwfUnderlay、GeomapImage、PdfUnderlay、RasterImage、Wipeout
此属性应用于的对象。
只读:不
类型:布尔
  • True:裁剪边界已启用。
  • False:未启用剪裁边界。
您可以使用剪切边界显示剪裁的图像或参考底图,也可以隐藏剪切边界并显示原始图像或参考底图边界。若要设置剪切边界,请使用以下方法。ClipBoundary
Sub Example_ClippingEnabled()
    ' This example adds a raster image in model space.
    ' It then clips the image based on a clip boundary,
    ' and toggles the display of the clipping.
    Dim scalefactor As Double
    Dim rotationAngle As Double
    Dim imageName As String
    Dim rasterObj As AcadRasterImage
    imageName = "C:\AutoCAD\sample\2d Projected Polylines.jpg"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0#
    scalefactor = 2#
    rotationAngle = 0
    On Error Resume Next
    ' Creates a raster image in model space
    Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotationAngle)
    If Err.Description = "Filer error" Then
        MsgBox imageName & " could not be found."
        Exit Sub
    End If
    ZoomAll
    MsgBox "Clip the image?", , "ClipBoundary Example"
    ' Establish the clip boundary with an array of points
    Dim clipPoints(0 To 9) As Double
    clipPoints(0) = 6: clipPoints(1) = 6.75
    clipPoints(2) = 7: clipPoints(3) = 6
    clipPoints(4) = 6: clipPoints(5) = 5
    clipPoints(6) = 5: clipPoints(7) = 6
    clipPoints(8) = 6: clipPoints(9) = 6.75
    ' Clip the image
    rasterObj.clipBoundary clipPoints
    ' Enable the display of the clip
    rasterObj.ClippingEnabled = True
    ThisDrawing.Regen acActiveViewport
    MsgBox "Turn off the display of the clipped image.", , "ClippingEnabled Example"
    ' Disable the display of the clip
    rasterObj.ClippingEnabled = False
    MsgBox "Display off.", , "ClippingEnabled Example"
(defun c:Example_ClippingEnabled()
    ;; This example adds a raster image in model space.
    ;; It then clips the image based on a clip boundary.
    ;; This example uses the "downtown.jpg" found in the Sample
    ;; directory. If you do not have the image, or if it is located
    ;; in a different directory, insert a valid path and name for the
    ;; imageName variable below.
    (setq insertionPoint (vlax-3d-point 5 5 0)
          imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
          scalefactor 2
          rotationAngle 0)
    (if (/= (findfile ".\\Sample\\VBA\\2d Projected Polylines.jpg") nil)
        (progn
	    ;; Creates a raster image in model space
            (setq rasterObj (vla-AddRaster modelSpace (findfile ".\\Sample\\VBA\\2d Projected Polylines.jpg") insertionPoint scalefactor rotationAngle))
	    (vla-ZoomAll acadObj)
	    (alert "Clip the image?")
	    ;; Establish the clip boundary with an array of points
	    (setq clipPoints (vlax-make-safearray vlax-vbDouble '(0 . 9)))
	    (vlax-safearray-fill clipPoints '(6 6.75
					      7 6
					      6 5
					      5 6
					      6 6.75
	    ;; Clip the image
	    (vla-ClipBoundary rasterObj clipPoints)
            ;; Enable the display of the clip
            (vla-put-ClippingEnabled rasterObj :vlax-true)
            (vla-Regen doc acActiveViewport)
            (alert "Turn off the display of the clipped image.")
            ;; Disable the display of the clip
            (vla-put-ClippingEnabled rasterObj :vlax-false)
            (alert "Clip boundary off.")
        (alert (strcat imageName " could not be found."))
GMT+8, 2026-11-15 12:16
