CenterPlot 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 1019| 评论: 0|原作者: admin|来自: AutoCAD
指定绘图在介质上的居中位置。
object.CenterPlot
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:布尔
  • True:将情节集中在媒体上。
  • False:不要将情节集中在媒体上。
在重新生成图形之前,对此属性的更改将不可见。使用该方法重新生成图形。Regen
不能在属性设置为 的布局对象上将此属性设置为 。TruePlotTypeacLayout
Sub Example_CenterPlot()
    ' This example will access the Layouts collection for the current drawing
    ' and display whether the plot for this layout is to be centered on the media.
    ' It will then toggle the state of CenterPlot for "Layout1" and re-display the
    ' CenterPlot state for each Layout.
    Dim Layouts As AcadLayouts, Layout As ACADLayout
    Dim msg As String
    Dim IsCentered As String
    ' Get layouts collection from document object
    Set Layouts = ThisDrawing.Layouts
    ' Display current layout information
    GoSub DISPLAY
    ' Toggle centered state for Layout1
    Layouts("Layout1").PlotType = acDisplay
    Layouts("Layout1").CenterPlot = Not (Layouts("Layout1").CenterPlot)
    ' Display new layout information
    GoSub DISPLAY
    Exit Sub
DISPLAY:
    msg = ""    ' Clear message
    ' Determine whether this layout is centered on the media during a plot
    For Each Layout In Layouts
        IsCentered = IIf(Layout.CenterPlot, " are centered ", " are not centered ")
        ' Format for display
        msg = msg & "Objects for " & Layout.name & IsCentered & "on the media during a plot." & vbCrLf
    Next
    ' Display layout information
    MsgBox msg
    Return
(defun c:Example_CenterPlot()
    ;; This example will access the Layouts collection for the current drawing
    ;; and display whether the plot for this layout is to be centered on the media.
    ;; It will then toggle the state of CenterPlot for "Layout1" and re-display the
    ;; CenterPlot state for each Layout.
    ;; Get layouts collection from document object
    (setq Layouts (vla-get-Layouts doc))
    ;; Display current layout information
    (setq msg "")    ;; Clear message
    ;; Determine whether this layout is centered on the media during a plot
    (vlax-for Layout Layouts
        (setq IsCentered (if (= (vla-get-CenterPlot Layout) :vlax-true) " are centered " " are not centered "))
        ;; Format for display
        (setq msg (strcat msg "Objects for " (vla-get-Name Layout) IsCentered "on the media during a plot.\n"))
    ;; Display layout information
    (alert msg)
    ;; Toggle centered state for Layout1
    (vla-put-PlotType (vla-Item Layouts "Layout1") acDisplay)
    (vla-put-CenterPlot (vla-Item Layouts "Layout1") (if (= (vla-get-CenterPlot (vla-Item Layouts "Layout1")) :vlax-true) :vlax-false :vlax-true))
    ;; Display new layout information
    (alert msg)
GMT+8, 2026-11-15 12:16
