Center 属性 (ActiveX)
2024-5-18 18:45| 发布者: admin| 查看: 1012| 评论: 0|原作者: admin|来自: AutoCAD
Center 属性 (ActiveX)
指定圆弧、圆、椭圆、视图或视口的中心。
object.Center
类型:弧形、圆形、DimRadialLarge、椭圆、PViewport、视图、视口
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
表示对象中心的 3D 坐标。默认中心为 (0,0,0)。
视口、视图:视口和视图对象的中心是 2D 坐标。
Sub Example_Center()
    Dim circObj As AcadCircle
    Dim currCenterPt(0 To 2) As Double
    Dim newCenterPt(0 To 2) As Double
    Dim radius As Double
    ' Define the initial center point and radius for the circle
    currCenterPt(0) = 20: currCenterPt(1) = 30: currCenterPt(2) = 0
    radius = 3
    ' Create the circle in model space
    Set circObj = ThisDrawing.ModelSpace.AddCircle(currCenterPt, radius)
    ZoomAll
    MsgBox "The center point of the circle is " & currCenterPt(0) & ", " & currCenterPt(1) & ", " & currCenterPt(2), vbInformation, "Center Example"
    ' Change the center point of the circle
    newCenterPt(0) = 25: newCenterPt(1) = 25: newCenterPt(2) = 0
    circObj.center = newCenterPt
    circObj.Update
    ' Query the results of the new center position
    ' Notice the output from the center property is a variant
    Dim centerPoint As Variant
    centerPoint = circObj.center
    MsgBox "The center point of the circle is " & centerPoint(0) & ", " & centerPoint(1) & ", " & centerPoint(2), vbInformation, "Center Example"
(defun c:Example_Center()
    ;; Define the initial center point and radius for the circle
    (setq currCenterPt (vlax-3d-point 20 30 0)
          radius 3)
    ;; Create the circle in model space
    (setq circObj (vla-AddCircle modelSpace currCenterPt radius))
    (vla-ZoomAll acadObj)
    (alert (strcat "The center point of the circle is"
		   "\n" (rtos (nth 0 (vlax-safearray->list (vlax-variant-value currCenterPt)))) ", "
		   (rtos (nth 1 (vlax-safearray->list (vlax-variant-value currCenterPt)))) ", "
		   (rtos (nth 2 (vlax-safearray->list (vlax-variant-value currCenterPt))))
    ;; Change the center point of the circle
    (setq newCenterPt (vlax-3d-point 25 25 0))
    (vla-put-Center circObj newCenterPt)
    (vla-Update circObj)
    ;; Query the results of the new center position
    ;; Notice the output from the center property is a variant
    (setq centerPoint (vlax-variant-value (vla-get-Center circObj)))
		   "\n" (rtos (nth 0 (vlax-safearray->list centerPoint))) ", "
		   (rtos (nth 1 (vlax-safearray->list centerPoint))) ", "
		   (rtos (nth 2 (vlax-safearray->list centerPoint)))
GMT+8, 2026-11-15 14:37
