CategoryName 属性 (ActiveX)
指定视图的类别名称。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 视图的类别名称。 言论没有其他评论。 例子VBA: Sub Example_CategoryName()
' This example demonstrates the
' CategoryName, LayoutId, LayerState,
' and HasVpAssociation properties of the View object
Dim oLSM As AcadLayerStateManager
' Access the LayerStateManager object
Set oLSM = ThisDrawing.Application. _
GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(AcadApplication.Version, 2))
' Associate the current drawing database with LayerStateManager
oLSM.SetDatabase ThisDrawing.Database
oLSM.Save "ColorLinetype", acLsColor + acLsLineType
' Create a view named "New_View" in current drawing
Dim viewObj As AcadView
' Add the view to the views collection
Set viewObj = ThisDrawing.Views.Add("New_View")
MsgBox viewObj.Name & " has been added." & vbCrLf & _
"Height: " & viewObj.Height & vbCrLf & _
"Width: " & viewObj.Width, , "Example"
viewObj.CategoryName = "My View Category"
viewObj.LayerState = "My Layer State"
viewObj.LayoutId = ThisDrawing.Layouts(1).ObjectID
MsgBox viewObj.CategoryName & " is the Category name." & vbCrLf & _
viewObj.LayoutId & " is the Layout ID." & vbCrLf & _
viewObj.LayerState & " is the Layer state."
If viewObj.HasVpAssociation = True Then
MsgBox "The view is associated with a paper space viewport."
Else
MsgBox "The view is not associated with a paper space viewport."
End If
可视化 LISP: (vl-load-com)
(defun c:Example_CategoryName()
;; This example demonstrates the
;; CategoryName, LayoutId, LayerState,
;; and HasVpAssociation properties of the View object
;; Access the LayerStateManager object
(setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
;; Associate the current drawing database with LayerStateManager
(vla-SetDatabase oLSM (vla-get-Database doc))
(vla-Save oLSM "ColorLinetype" (+ acLsColor acLsLineType))
;; Add the view to the views collection
(setq viewObj (vla-Add (vla-get-Views doc) "New_View"))
(alert (strcat (vla-get-Name viewObj) " has been added."
"\nHeight: " (rtos (vla-get-Height viewObj) 2)
"\nWidth: " (rtos (vla-get-Width viewObj) 2)
(vla-put-CategoryName viewObj "My View Category")
(vla-put-LayerState viewObj "My Layer State")
(vla-put-LayoutId viewObj (vla-get-ObjectID (vla-Item (vla-get-Layouts doc) 1)))
(alert (strcat (vla-get-CategoryName viewObj) " is the Category name."
"\n" (itoa (vla-get-LayoutId viewObj)) " is the Layout ID."
"\n" (vla-get-LayerState viewObj) " is the Layer state."
(if (= (vla-get-HasVpAssociation viewObj) :vlax-true)
(alert "The view is associated with a paper space viewport.")
(alert "The view is not associated with a paper space viewport.")
(vlax-release-object oLSM)
GMT+8, 2026-11-15 11:52
