ArrowheadBlock 属性 (ActiveX)
指定要用作径向尺寸或引线的自定义箭头的块。 支持的平台:仅限 Windows 签名VBA: object.ArrowheadBlock
属性值只读:不 类型:字符串 用作引线箭头的块的名称。 言论
注意:此属性将覆盖给定维度的 DIMLDRBLK 系统变量的值。
例子VBA: Sub Example_ArrowHeadBlock()
' This example creates a radial dimension object in model space
' and then alters the visible appearance (shape) of the arrowhead
' using the ArrowHeadBlock property.
' Use the ArrowHeadBlock property to set the arrowhead to an existing
' block object containing a custom Circle object
Dim dimObj As AcadDimRadial
Dim center(0 To 2) As Double
Dim chordPoint(0 To 2) As Double
Dim leaderLen As Integer
Dim BlockName As String
' Define the dimension
center(0) = 0#: center(1) = 0#: center(2) = 0#
chordPoint(0) = 5#: chordPoint(1) = 5#: chordPoint(2) = 0#
leaderLen = 5
' Create the radial dimension in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimRadial(center, chordPoint, leaderLen)
ZoomAll
' Set arrowhead type to user-defined to allow
' the use of a block as the new arrowhead
'dimObj.ArrowheadType = acArrowUserDefined
dimObj.ArrowheadBlock = "CBlock"
ZoomAll
' Read and display current arrowhead block name
BlockName = dimObj.ArrowheadBlock
MsgBox "The arrowhead block name for this object is: " & BlockName
可视化 LISP: (vl-load-com)
(defun c:Example_ArrowHeadBlock()
;; This example creates a radial dimension object in model space
;; and then alters the visible appearance (shape) of the arrowhead
;; using the ArrowHeadBlock property.
;; Use the ArrowHeadBlock property to set the arrowhead to an existing
;; block object containing a custom Circle object
;; Define the dimension
(setq center (vlax-3d-point 0 0 0)
chordPoint (vlax-3d-point 5 5 0)
leaderLen 5)
;; Create the radial dimension in model space
(setq dimObj (vla-AddDimRadial modelSpace center chordPoint leaderLen))
(vla-ZoomAll acadObj)
;; Use the custom block as the new arrowhead, the block must exist in the drawing
(vla-put-ArrowheadBlock dimObj "CBlock")
;; Read and display current arrowhead block name
(setq BlockName (vla-get-ArrowheadBlock dimObj))
(alert (strcat "The arrowhead block name for this object is: " BlockName))
GMT+8, 2026-11-15 12:35
