Annotation 属性 (ActiveX)
指定引线的批注对象。 支持的平台:仅限 Windows 言论并非所有引线都有批注对象。如果引线没有注释,则此属性将返回(逻辑)。若要测试 VB 或 VBA 中的逻辑值,请使用关键字。NothingFalseFalseNothing 例子VBA: Sub Example_Annotation()
' This example creates a leader in model space with an associated
' annotation and then checks for the existence of an
' Annotation object for the new Leader
Dim leaderObj As AcadLeader, MTextObj As AcadMText
Dim points(0 To 8) As Double, insertionPoint(0 To 2) As Double, width As Double
Dim leaderType As Integer
Dim annotationObject As Object
Dim textString As String, msg As String
' Define the new MText object
textString = "Hello, World."
insertionPoint(0) = 5: insertionPoint(1) = 5: insertionPoint(2) = 0
width = 2
' Create the MText object in model space
Set MTextObj = ThisDrawing.ModelSpace.AddMText(insertionPoint, width, textString)
' Data for Leader
points(0) = 0: points(1) = 0: points(2) = 0
points(3) = 4: points(4) = 4: points(5) = 0
points(6) = 4: points(7) = 5: points(8) = 0
leaderType = acLineWithArrow
' Create the Leader object in model space and Associate new MText object
' with new Leader by making the MText object the annotation for the Leader
Set annotationObject = MTextObj
Set leaderObj = ThisDrawing.ModelSpace.AddLeader(points, annotationObject, leaderType)
' Display whether or not this particular Leader has an associated Annotation
msg = IIf(leaderObj.Annotation Is Nothing, "does not have", "has")
MsgBox "The new Leader object " & msg & " an associated Annotation object."
可视化 LISP: (vl-load-com)
(defun c:Example_Annotation()
;; This example creates a leader in model space with an associated
;; annotation and then checks for the existence of an
;; Annotation object for the new Leader
;; Define the new MText object
(setq insertionPoint (vlax-3d-point 5 5 0)
textString "Hello, World."
width 2)
;; Create the MText object in model space
(setq MTextObj (vla-AddMText modelSpace insertionPoint width textString))
;; Data for Leader
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill points '(0 0 0
4 4 0
4 5 0
(setq leaderType acLineWithArrow)
;; Create the Leader object in model space and Associate new MText object
;; with new Leader by making the MText object the annotation for the Leader
(setq annotationObject MTextObj)
(setq leaderObj (vla-AddLeader modelSpace points annotationObject leaderType))
(vla-ZoomAll acadObj)
(alert "The new Leader object has an associated Annotation object.")
GMT+8, 2026-11-15 12:36
