AltSuppressZeroInches 属性 (ActiveX)
指定在备用尺寸值中隐含零英寸测量值。 支持的平台:仅限 Windows 签名VBA: object.AltSuppressZeroInches
属性值只读:不 类型:布尔
言论此属性的初始值为 。False
注意:此属性将覆盖给定维度的 DIMALTZ 系统变量的值。
例子VBA: Sub Example_AltSuppressZeroInches()
' uses AltSuppressZeroInches to suppress or view the display of
' zero inches in the alternate dimension display
Dim dimObj As AcadDimAligned
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 12: point2(1) = 5: point2(2) = 0
' Enable alternate unit display
dimObj.AltUnits = True
' Set the dimension display to a style that works with AltSuppressZeroInches
dimObj.AltUnitsFormat = acDimLArchitectural
dimObj.AltUnitsScale = 2 ' Set the alternate unit scale to be a multiple of 2
Toggle:
Select Case MsgBox("Press OK to suppress or view the display of zero inches in the alternate dimension", vbOKCancel)
Case vbOK
' Toggle the display of zero inches for the alternate dimension value
dimObj.AltSuppressZeroInches = Not (dimObj.AltSuppressZeroInches)
Case vbCancel
Exit Sub
End Select
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_AltSuppressZeroInches()
;; uses AltSuppressZeroInches to suppress or view the display of
;; zero inches in the alternate dimension display
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5 5 0)
;; Enable alternate unit display
(setq originalValue (vla-get-AltSuppressZeroInches dimObj))
(vla-put-AltUnits dimObj :vlax-true)
;; Set the dimension display to a style that works with AltSuppressZeroInches
(vla-put-AltUnitsFormat dimObj acDimLArchitectural)
(vla-put-AltUnitsScale dimObj 2) ;; Set the alternate unit scale to be a multiple of 2
(vla-ZoomAll acadObj)
(alert "Toggling the display of zero inches in the alternate tolerance.")
(vla-put-AltSuppressZeroInches dimObj (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-AltSuppressZeroInches dimObj))
(alert "Toggling the display of zero inches in the alternate tolerance to original value.")
(vla-put-AltSuppressZeroInches dimObj (if (= newValue :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-11-15 11:45
