AltFontFile 属性 (ActiveX)
指定如果 AutoCAD 找不到原始字体且未在字体映射文件中指定备用字体时要使用的字体文件的位置。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 备用字体文件。 言论没有其他评论。 例子VBA: Sub Example_AltFontFile()
' AltFontFile. It then changes the value, and finally
Dim currAltFontFile As String
Dim newAltFontFile As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current AltFontFile value
currAltFontFile = preferences.Files.AltFontFile
MsgBox "The current value for AltFontFile is " & currAltFontFile, vbInformation, "AltFontFile Example"
' Change the value for AltFontFile
newAltFontFile = "C:/AutoCAD/Fonts/gothice.shx"
preferences.Files.AltFontFile = newAltFontFile
MsgBox "The new value for AltFontFile is " & newAltFontFile, vbInformation, "AltFontFile Example"
' Reset AltFontFile to its original value
preferences.Files.AltFontFile = currAltFontFile
MsgBox "The AltFontFile value is reset to " & currAltFontFile, vbInformation, "AltFontFile Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AltFontFile()
;; AltFontFile. It then changes the value, and finally
(setq files (vla-get-Files preferences))
;; Retrieve the current AltFontFile value
(setq currAltFontFile (vla-get-AltFontFile files))
(alert (strcat "The current value for AltFontFile is " currAltFontFile))
;; Change the value for AltFontFile
(setq newAltFontFile "C:/AutoCAD/Fonts/gothice.shx")
(vla-put-AltFontFile files newAltFontFile)
(alert (strcat "The new value for AltFontFile is " newAltFontFile))
;; Reset AltFontFile to its original value
(vla-put-AltFontFile files currAltFontFile)
(alert (strcat "The AltFontFile value is reset to " currAltFontFile))
GMT+8, 2026-11-15 12:15
