Update 方法 (ActiveX)
将对象更新到绘图屏幕。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_Update()
' This example creates a line in model space. It displays a
' Msgbox immediately before the call to update the line and
' again after the call.
Dim lineObj As AcadLine
' Create a Line object in model space
startPoint(0) = 2#: startPoint(1) = 2#: startPoint(2) = 0#
endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
MsgBox "Before the update.", , "Update Example"
' The following code draws an object in AutoCAD window
lineObj.Update
MsgBox "After the update.", , "Update Example"
' The following call updates the entire drawing
ThisDrawing.Application.Update
可视化 LISP: (vl-load-com)
(defun c:Example_Update()
;; This example creates a line in model space. It displays a
;; Msgbox immediately before the call to update the line and
;; again after the call.
;; Create a Line object in model space
(setq startPoint (vlax-3d-point 2 2 0)
endPoint (vlax-3d-point 4 4 0))
(vla-ZoomAll acadObj)
(alert "Before the update.")
;; The following code draws an object in AutoCAD window
(vla-Update lineObj)
(alert "After the update.")
;; The following call updates the entire drawing
(vla-Update acadObj)
GMT+8, 2026-11-15 11:53
