Rotate3D 方法 (ActiveX)
2024-5-18 18:44| 发布者: admin| 查看: 886| 评论: 0|原作者: admin|来自: AutoCAD
绕 3D 轴旋转对象。Point1 和 Point2 定义成为旋转轴的线。
object.Rotate3D Point1, Point2, RotationAngle
类型:所有绘图对象、AttributeReference、尺寸
此方法应用到的对象。
第1点
访问:仅输入
类型:变体(双打的三元素阵列)
指定轴线第一点的 3D WCS 坐标。
第2点
访问:仅输入
类型:变体(双打的三元素阵列)
指定轴线的第二个点的 3D WCS 坐标。
旋转角度
访问:仅输入
类型:双
围绕所选轴旋转对象的角度(以弧度为单位)。
返回值 (RetVal)
无返回值。
Sub Example_Rotate3D()
    ' This example creates a box in model space.
    ' It then rotates the box about an axis.
    Dim boxObj As Acad3DSolid
    Dim length As Double, width As Double, height As Double
    Dim center(0 To 2) As Double
    ' Define the box
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 5#: width = 7: height = 10#
    ' Create the box (3DSolid) object in model space
    Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
    ' Change the viewing direction of the viewport
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ThisDrawing.Regen True
    ' Define the rotation axis with two points
    Dim rotatePt1(0 To 2) As Double
    Dim rotatePt2(0 To 2) As Double
    Dim rotateAngle As Double
    rotatePt1(0) = -3: rotatePt1(1) = 4: rotatePt1(2) = 0
    rotatePt2(0) = -3: rotatePt2(1) = -4: rotatePt2(2) = 0
    rotateAngle = 30
    rotateAngle = rotateAngle * 3.141592 / 180#
    ' Draw a line between the two axis points so that it is visible.
    ' This is optional. It is not required for the rotation.
    Dim axisLine As AcadLine
    Set axisLine = ThisDrawing.ModelSpace.AddLine(rotatePt1, rotatePt2)
    axisLine.Update
    MsgBox "Rotate the box 30 degrees about the axis shown.", , "Rotate3D Example"
    ' Rotate the box
    boxObj.Rotate3D rotatePt1, rotatePt2, rotateAngle
    MsgBox "The box is rotated 30 degrees.", , "Rotate3D Example"
(defun c:Example_Rotate3D()
    ;; This example creates a box in model space.
    ;; It then rotates the box about an axis.
    ;; Define the box
    (setq center (vlax-3d-point 5 5 0)
          boxLength 5
	         boxWidth 7
	         boxHeight 10)
    ;; Create the box (3DSolid) object in model space
    (setq boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
    ;; Change the viewing direction of the viewport
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
    ;; Define the rotation axis with two points
    (setq rotatePt1 (vlax-3d-point -3 4 0)
          rotatePt2 (vlax-3d-point -3 -4 0)
          rotateAngle (/ (* 30 3.141592) 180))
    ;; Draw a line between the two axis points so that it is visible.
    ;; This is optional. It is not required for the rotation.
    (setq axisLine (vla-AddLine modelSpace rotatePt1 rotatePt2))
    (vla-Update axisLine)
    (alert "Rotate the box 30 degrees about the axis shown.")
    ;; Rotate the box
    (vla-Rotate3D boxObj rotatePt1 rotatePt2 rotateAngle)
    (vla-Regen doc :vlax-true)
    (alert "The box is rotated 30 degrees.")
GMT+8, 2026-11-15 12:01
