PutRemoteFile 方法 (ActiveX)
2024-5-18 18:44| 发布者: admin| 查看: 931| 评论: 0|原作者: admin|来自: AutoCAD
将文件上载到 AutoCAD 已知的 URL 指定的远程 FTP 位置。
object.PutRemoteFile URL, LocalFile
类型: 实用程序
此方法应用到的对象。
网址
访问:仅输入
类型:字符串
要将文件上传到的 URL 位置。
本地文件
访问:仅输入
类型:字符串
要上传的文件。
返回值 (RetVal)
无返回值。
该方法旨在补充该方法。GetRemoteFile
访问安全 URL 时,会出现一个对话框,提示用户输入必要的密码信息。如果用户尚未在其浏览器中禁止此活动,则会显示消息框。
Sub Example_PutRemoteFile()
    ' This example transfers a local file to a remote URL.  Since this example
    ' relies on both a remote server name and a local file, you will have to
    ' modify both the DestURL and LocalFile variables below to run this example.
    Dim DestURL As String, LocalFile As String
    ' Define source and destination
    DestURL = "ftp://www.myserver.com/autocadfiles/"
    LocalFile = "c:\program files\autocad\sample\city map.dwg"
    ' Transfer local file to remote location
    ThisDrawing.Utility.PutRemoteFile DestURL, LocalFile
    MsgBox LocalFile & " was just transfered to: " & DestURL
(defun c:Example_PutRemoteFile()
    ;; This example transfers a local file to a remote URL.  Since this example
    ;; relies on both a remote server name and a local file, you will have to
    ;; modify both the DestURL and LocalFile variables below to run this example.
    ;; Define source and destination
    (setq DestURL "ftp://www.myserver.com/autocadfiles/")
    (setq LocalFile "C:\\autocad\\samples\\city map.dwg")
    ;; Transfer local file to remote location
    (vla-PutRemoteFile (vla-get-Utility doc) DestURL LocalFile)
    (alert (strcat LocalFile " was just transfered to: " DestURL))
GMT+8, 2026-11-15 11:41
