HandleToObject 方法 (ActiveX)
获取对应于给定句柄的对象。 支持的平台:仅限 Windows 返回值 (RetVal)类型:对象 与给定句柄对应的对象。 言论此方法只能返回当前文档中的对象。 例子VBA: Sub Example_HandleToObject()
' This example creates a spline in model space, and returns the
' handle for the spline. Then the spline is returned from the handle and colored.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
' Find the handle of the spline
Dim handle As String
handle = splineObj.handle
MsgBox "The handle of the Spline is: " & splineObj.handle, , "HandleToObject Example"
' Find an object from a given handle
Dim tempObj As AcadObject
Set tempObj = ThisDrawing.HandleToObject(handle)
' Now use the newly initialized object variable to color the object
Dim color As AcadAcCmColor
Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
Call color.SetRGB(80, 100, 244)
tempObj.TrueColor = color
ThisDrawing.Regen True
MsgBox "The Spline is now blue.", , "ObjectIDToObject Example"
可视化 LISP: (vl-load-com)
(defun c:Example_HandleToObject()
;; This example creates a spline in model space, and returns the
;; handle for the spline. Then the spline is returned from the handle and colored.
;; Create the spline
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(1 1 0
5 5 0
10 0 0
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Find the handle of the spline
(setq handle (vla-get-Handle splineObj))
(alert (strcat "The handle of the Spline is: " handle))
;; Find an object from a given handle
(setq tempObj (vla-HandleToObject doc handle))
;; Now use the newly initialized object variable to color the object
(setq color (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
(vla-SetRGB color 80 100 244)
(vla-put-TrueColor tempObj color)
(vla-Regen doc :vlax-true)
(alert "The Spline is now blue.")
(vlax-release-object color)
GMT+8, 2026-11-15 13:31
