GetRemoteFile 方法 (ActiveX)
下载 URL 指定的文件。 支持的平台:仅限 Windows 签名VBA: object.GetRemoteFile URL, LocalFile, IgnoreCache
返回值 (RetVal)无返回值。 言论如果维护已在当前会话或上一个会话(缓存)中下载的文件列表,则避免重复传输并改为创建本地可用文件的副本可能会更有效。您可以通过将 IgnoreCache 参数设置为 显式强制下载,在这种情况下,缓存将被完全绕过。True 访问安全 URL 时,将发布一个对话框,提示用户输入必要的密码信息。如果用户尚未在浏览器中禁止此活动,则还会显示消息框。 下载文件时,AutoCAD 会创建一个临时文件进行内部处理。不要尝试访问此临时文件。此文件中的信息将在 AutoCAD 任务结束时删除。 例子VBA: Sub Example_GetRemoteFile()
' This example will prompt the user for a URL to download and will verify that
' a proper URL was entered. After downloading, the example will attempt to load
' the downloaded URL as a drawing.
' * Note: Remember to delete the downloaded file from your disk drive when finished.
Dim Utility As AcadUtility
Dim URL As String, DestFile As String, FileURL As String
Set Utility = ThisDrawing.Utility ' Connect to Utility object
GETURL:
' Prompt user for a URL to download. This should be a URL to an AutoCAD drawing file.
URL = Utility.GetString(False, vbLf & "Enter the complete URL of the file you wish to download: ")
URL = Trim(URL) ' Get rid of blank spaces
If URL = "" Then Exit Sub ' Did user cancel
' Determine if user entered a valid URL; if not, prompt again
If Not (Utility.IsURL(URL)) Then
MsgBox "The URL you entered is not valid. Make sure the syntax is a valid URL."
GoTo GETURL
End If
' Download URL
Utility.GetRemoteFile URL, DestFile, True
' Display downloaded file information
MsgBox URL & " was downloaded to: " & DestFile
' Use IsRemoteFile to determine if this file was downloaded from a URL.
' If it was, display the URL it was downloaded from
' * Note: Although the results that IsRemoteFile will return are already known
' since the file was just downloaded it is important to know how this
' method can be used.
If Utility.IsRemoteFile(DestFile, FileURL) Then
MsgBox "The file: " & DestFile & " is a downloaded file and was downloaded from: " & FileURL
Else
MsgBox "The file: " & DestFile & " is not a downloaded file."
End If
可视化 LISP: (vl-load-com)
(defun c:Example_GetRemoteFile()
;; This example will prompt the user for a URL to download and will verify that
;; a proper URL was entered. After downloading, the example will provide information
;; about the downloaded drawing.
;; * Note: Remember to delete the downloaded file from your disk drive when finished.
(setq Utility (vla-get-Utility doc)) ;; Connect to Utility object
;; Prompt user for a URL to download. This should be a URL to an AutoCAD drawing file.
(setq URL (vla-GetString Utility :vlax-false "\nEnter the complete URL of the file you wish to download: "))
(if (/= URL "")
(progn
(if (= (vla-IsURL Utility URL) :vlax-false)
(alert "The URL you entered is not valid. Make sure the syntax is a valid URL.")
(progn
;; Download URL
(vla-GetRemoteFile Utility URL 'DestFile :vlax-true)
;; Display downloaded file information
(alert (strcat URL " was downloaded to: " DestFile "\n"))
;; Use IsRemoteFile to determine if this file was downloaded from a URL.
;; If it was, display the URL it was downloaded from
;; * Note: Although the results that IsRemoteFile will return are already known
;; since the file was just downloaded it is important to know how this
;; method can be used.
(if (= (vla-IsRemoteFile Utility DestFile URL) :vlax-true)
(alert (strcat "The file: " DestFile " is a downloaded file and was downloaded from: " URL))
(alert (strcat "The file: " DestFile " is not a downloaded file."))
GMT+8, 2026-11-15 12:10
