GetCustomScale 方法 (ActiveX)
2024-5-18 18:44| 发布者: admin| 查看: 875| 评论: 0|原作者: admin|来自: AutoCAD
获取布局或打印配置的自定义比例。
object.GetCustomScale Numerator, Denominator
类型:布局、PlotConfiguration
此方法应用到的对象。
分子
访问:仅输出
类型:双
比例比中的分子。此值表示刻度的英寸数或毫米数。
分母
访问:仅输出
类型:双
比例比率中的分母。此值表示比例的绘图单位数。
返回值 (RetVal)
无返回值。
Numerator 参数取决于属性的设置。PaperUnits
Sub Example_GetCustomScale()
    ' This example will access the Layouts collection for the current drawing
    ' and list basic information about the custom scale for each Layout.
    ' It will then change the custom scale information for model space and re-display
    ' the scale information.
    Dim Layouts As AcadLayouts, Layout As ACADLayout
    Dim msg As String
    Dim Numerator As Double, Denominator As Double
    Dim Measurement As String
    ' Display current scale information
    GoSub DISPLAY_SCALE_INFO
    ' Modify scale
    Numerator = 1
    Denominator = 1
    ThisDrawing.Layouts("Model").SetCustomScale Numerator, Denominator
    ' Display new scale information
    Exit Sub
DISPLAY_SCALE_INFO:
    ' Get layouts collection from document object
    Set Layouts = ThisDrawing.Layouts
    msg = vbCrLf & vbCrLf   ' Start with a space
    ' Get the scale information of every layout in this drawing
    For Each Layout In Layouts
        msg = msg & Layout.name & vbCrLf
        ' Get scale information
        Layout.GetCustomScale Numerator, Denominator
        ' Are we using inches or millimeters
        Measurement = IIf(Layout.PaperUnits = acInches, " inch(es)", " millimeter(s)")
        ' Format for display
        msg = msg & vbTab & "Contains " & Numerator & Measurement & vbCrLf
        msg = msg & vbTab & "Contains " & Denominator & " drawing units" & vbCrLf
        msg = msg & "_____________________" & vbCrLf
    Next
    ' Display custom scale information
    MsgBox "Custom scale information for the current drawing is: " & msg
    Return
(defun c:Example_GetCustomScale()
    ;; This example will access the Layouts collection for the current drawing
    ;; and list basic information about the custom scale for each Layout.
    ;; It will then change the custom scale information for model space and re-display
    ;; the scale information.
    ;; Display current scale information
    (setq Layouts (vla-get-Layouts doc))
    (setq msg "")
    ;; Get the scale information of every layout in this drawing
    (vlax-for Layout Layouts
        (setq msg (strcat msg (vla-get-Name Layout) "\n"))
        ;; Get scale information
        (vla-GetCustomScale Layout 'Numerator 'Denominator)
        ;; Are we using inches or millimeters
        (setq Measurement (if (= (vla-get-PaperUnits Layout) acInches) " inch(es)\n" " millimeter(s)\n"))
        ;; Format for display
        (setq msg (strcat msg "  Contains " (rtos Numerator 2) Measurement
                              "  Contains " (rtos Denominator 2) " drawing units\n"
                              "_____________________\n"))
    ;; Display custom scale information
    (alert (strcat "Custom scale information for the current drawing is: " msg))
    ;; Modify scale
    (setq Numerator 1
          Denominator 1)
    (vla-SetCustomScale (vla-Item (vla-get-Layouts doc) "Model") Numerator Denominator)
    ;; Display new scale information
    (setq msg "")
GMT+8, 2026-11-15 12:42
