AppendInnerLoop 方法 (ActiveX)
在填充物上附加一个内环。 支持的平台:仅限 Windows 签名VBA: object.AppendInnerLoop Loop 返回值 (RetVal)无返回值。 言论使用该方法创建对象后,使用 添加外部循环。必须关闭外部循环,并且必须先创建外部循环,然后才能添加任何内部循环。HatchAddHatchAppendOuterLoop 例子VBA: Sub Example_AppendInnerLoop()
' This example creates an associative hatch in model space, and then appends an outer loop to the hatch.
Dim hatchObj As AcadHatch
Dim patternName As String
Dim PatternType As Long
Dim bAssociativity As Boolean
' Define the hatch
patternName = "ANSI31"
PatternType = 0
bAssociativity = True
' Create the associative Hatch object
Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
' Create the outer loop for the hatch.
' An arc and a line are used to create a closed loop.
Dim outerLoop(0 To 1) As AcadEntity
Dim center(0 To 2) As Double
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
center(0) = 5: center(1) = 3: center(2) = 0
radius = 3
startAngle = 0
endAngle = 3.141592
Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle)
Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint)
' Append the outer loop to the hatch object
hatchObj.AppendOuterLoop (outerLoop)
' Append a circle as the inner loop for the hatch.
Dim innerLoop(0) As AcadEntity
center(0) = 5: center(1) = 4.5: center(2) = 0
radius = 1
Set innerLoop(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
hatchObj.AppendInnerLoop (innerLoop)
' Evaluate and display the hatch
hatchObj.Evaluate
ThisDrawing.Regen True
可视化 LISP: (vl-load-com)
(defun c:Example_AppendInnerLoop()
;; This example creates an associative hatch in model space, and then appends an outer loop to the hatch.
;; Define the hatch
(setq patternName "ANSI31"
patternType 0
bAssociativity :vlax-true)
;; Create the associative Hatch object
(setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject))
;; Create the outer loop for the hatch.
;; An arc and a line are used to create a closed loop.
(setq center (vlax-3d-point 5 3 0)
radius 3
startAngle 0
endAngle 3.141592)
(setq arc (vla-AddArc modelSpace center radius startAngle endAngle))
(setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc)))
(setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1)))
(vlax-safearray-put-element outerLoop 0 arc)
(vlax-safearray-put-element outerLoop 1 line)
;; Append the outer loop to the hatch object
(vla-AppendOuterLoop hatchObj outerLoop)
;; Append a circle as the inner loop for the hatch.
(setq center (vlax-3d-point 5 4.5 0)
radius 1)
(setq circle (vla-AddCircle modelSpace center radius))
(setq innerLoop (vlax-make-safearray vlax-vbObject '(0 . 0)))
(vlax-safearray-put-element innerLoop 0 circle)
(vla-AppendInnerLoop hatchObj innerLoop)
;; Evaluate and display the hatch
(vla-Evaluate hatchObj)
(vla-Regen doc :vlax-true)
GMT+8, 2026-11-16 12:13
