关于 3D 阵列 (VBA/ActiveX)
2024-5-18 18:43| 发布者: admin| 查看: 677| 评论: 0|原作者: admin|来自: AutoCAD
使用该方法,您可以在 3D 中创建一个矩形数组。ArrayRectangular
除了指定列数(X 方向)和行数(Y 方向)之外,还可以指定级别数(Z 方向)。
创建 3D 矩形阵列
本示例创建一个圆,然后使用该圆创建一个包含四行、四列和三级圆的矩形数组。
Sub Ch8_CreateRectangularArray()
    ' Create the circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 2: center(1) = 2: center(2) = 0
    radius = 0.5
    Set circleObj = ThisDrawing.ModelSpace. _
 AddCircle(center, radius)
    ' Define the rectangular array
    Dim numberOfRows As Long
    Dim numberOfColumns As Long
    Dim numberOfLevels As Long
    Dim distanceBwtnRows As Double
    Dim distanceBwtnColumns As Double
    Dim distanceBwtnLevels As Double
    numberOfRows = 4
    numberOfColumns = 4
    numberOfLevels = 3
    distanceBwtnRows = 1
    distanceBwtnColumns = 1
    distanceBwtnLevels = 4
    ' Create the array of objects
    Dim retObj As Variant
    retObj = circleObj.ArrayRectangular _
        (numberOfRows, numberOfColumns, _
         numberOfLevels, distanceBwtnRows, _
         distanceBwtnColumns, distanceBwtnLevels)
    ZoomAll
GMT+8, 2026-11-15 12:27
