关于编辑填充边界 (VBA/ActiveX)
您可以在填充边界中追加或插入环。关联填充将更新以匹配对其边界所做的任何更改。非关联填充线不会更新。 若要编辑填充边界,请使用下列方法之一:
将内环追加到填充物本示例创建一个关联填充。然后,它创建一个圆圈,并将该圆圈作为内环附加到舱口。 Sub Ch4_AppendInnerLoopToHatch() Dim hatchObj As AcadHatch Dim patternName As String Dim PatternType As Long Dim bAssociativity As Boolean ' Define and create the hatch patternName = "ANSI31" PatternType = 0 bAssociativity = True Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity) ' Create the outer loop for the hatch. Dim outerLoop(0 To 1) As AcadEntity Dim center(0 To 2) As Double Dim radius As Double Dim startAngle As Double Dim endAngle As Double center(0) = 5: center(1) = 3: center(2) = 0 radius = 3 startAngle = 0 endAngle = 3.141592 Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle) Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint) ' Append the outer loop to the hatch object hatchObj.AppendOuterLoop (outerLoop) ' Create a circle as the inner loop for the hatch. Dim innerLoop(0) As AcadEntity center(0) = 5: center(1) = 4.5: center(2) = 0 radius = 1 Set innerLoop(0) = ThisDrawing.ModelSpace.AddCircle(center, radius) ' Append the circle as an inner loop to the hatch hatchObj.AppendInnerLoop (innerLoop) ' Evaluate and display the hatch hatchObj.Evaluate ThisDrawing.Regen True End Sub |
GMT+8, 2026-11-15 14:46
