AutoCAD 2021 API 历史记录参考 (ActiveX)
对 AutoCAD 2021 和基于 AutoCAD 2021 的产品中的 ActiveX API 所做的添加和更改。 类AcadAcCmColor
Version number of the class has been incremented from 23 to 24; use the ProgID AutoCAD.AcCmColor.24
AcadApplication
Major version number of the class has been incremented from 23 to 24
Use the ProgID AutoCAD.Application.24 to create an instance of AutoCAD 2021.
AcadLayerStateManager
Version number of the class has been incremented from 23 to 24; use the ProgID AutoCAD.AcadLayerStateManager.24
AcadSecurityParams
Version number of the class has been incremented from 23 to 24; use the ProgID AutoCAD.SecurityParams.24
相关概念 |
GMT+8, 2026-11-15 12:39
