SliceSolid 方法 (ActiveX)
创建给定定义平面的三个点的 3DSolid 对象的切片。 支持的平台:仅限 Windows 签名VBA: RetVal = object.SliceSolid(Point1, Point2, Point3, Negative)
言论没有其他评论。 例子VBA: Sub Example_SliceSolid()
' This example creates a box in model space.
' It then slices the box based on a plane
' defined by three points. The slice is returned
' as a 3Dsolid.
Dim boxObj As Acad3DSolid
Dim length As Double, width As Double, height As Double
Dim center(0 To 2) As Double
' Define the box
center(0) = 5#: center(1) = 5#: center(2) = 0
length = 5#: width = 7: height = 10#
' Create the box (3DSolid) object in model space
Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
' Define the section plane with three points
Dim slicePt1(0 To 2) As Double
Dim slicePt2(0 To 2) As Double
Dim slicePt3(0 To 2) As Double
slicePt1(0) = 1.5: slicePt1(1) = 7.5: slicePt1(2) = 0
slicePt2(0) = 1.5: slicePt2(1) = 7.5: slicePt2(2) = 10
slicePt3(0) = 8.5: slicePt3(1) = 2.5: slicePt3(2) = 10
' slice the box
Dim sliceObj As Acad3DSolid
Set sliceObj = boxObj.SliceSolid(slicePt1, slicePt2, slicePt3, True)
' Change the viewing direction of the viewport
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_SliceSolid()
;; This example creates a box in model space.
;; It then slices the box based on a plane
;; defined by three points. The slice is returned
;; as a 3Dsolid.
;; Define the box
(setq center (vlax-3d-point 5 5 0)
boxLength 5
boxWidth 7
boxHeight 10)
;; Create the box (3DSolid) object in model space
(setq boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
;; Define the section plane with three points
(setq slicePt1 (vlax-3d-point 1.5 7.5 0)
slicePt2 (vlax-3d-point 1.5 7.5 10)
slicePt3 (vlax-3d-point 8.5 2.5 10))
;; slice the box
(setq sliceObj (vla-SliceSolid boxObj slicePt1 slicePt2 slicePt3 :vlax-true))
;; Change the viewing direction of the viewport
(setq NewDirection (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
(vla-ZoomAll acadObj)
GMT+8, 2026-11-15 11:55
